  • Replies 74
Spewin I had to work. Would love to have seen Mick run...And myself to...
Um, just checked the track times for the Sprint Track... ARe those times correct for all the categories?
Cause I've ran a fastest of 1:07.02 "DRY" street trim with SC fitted & 1:19.48 "WET" street trim and NA.
All in my humble R31 GTS1.... Surley I can't be mixing it with the turbo cars with boost and mods etc etc....I realise the "hand clicking" timing to..
Heres a easier one to read for the wet weather ones
(Wet) TRACK: Qld Raceway Sprint
GTR Class:
1:08.30, R33, jlNewton
GTS Class:
1:14.29, R33, SirSkyline
1:15.41, R32, nf.
1:16.10, R32, predator
1:16.68, R33, Toy33
1:20.30, R33, JCMarshall_Law
1:21.99, R33, Mr.R33
EVO Class:
TRACK: Qld Raceway Clubman
GTR Class:
1:14.60, R33, jlNewton
GTS Class:
1:17.46, R33, SirSkyline
1:18.58, R32, nf.
1:20.55, R33, Toy33
1:20.66, R31, predator
1:23.13, R33, JCMarshall_Law
1:23.76, R33, Mr.R33
EVO Class:
TRACK: Qld Raceway National Circuit
GTR Class:
GTS Class:
EVO Class:
Edited by SirSkyline
Thats about right. I ran consistant low 1:04s in my old GTST on the sprint layout with just a cat-back exhaust, pod filter, stock boost and Yokohama A539s 235/45 R17, in the dry of course.... Might bring the 33 sedan out for the next one too, see what it can do, That will keep me busy for the day :(
svd001: I think JCMarshall_Law meant real as in the guy hand clicking didn't make a mistake.
SirSkyline: Yea ok, you were after the result order rather than just the times. The reason I didn't do that is that "Wet" track can mean so many different things, like "constant rain" or "rained earlier but the line is drying" or "its raining so hard I cannot see".
Did all you guys collect your end of day time sheet before leaving ?
On the front page I've got Old Toy33 (GTS) and New Toy33 (GTR)
nf, if you mean the end of day sheet with all your laps, a graph of your performance and everyone else in rank order etc (the one jlnewton is referring too) , I printed them but not everyone collected them. If you want I'll post it out. Just PM me a mailing address.
Paul
AzzurrA, sorry not trying to appear to have 'l337' group, its just our times are done electronically to 1/100th sec. Whereas the normal times at Sprints are timed by hand (see posts above for full details). So the times kept in this thread are accurate results.
Paul
  • 2 months later...
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
