all these can be seen on yahoo auctions
True but navigating that site can be a pain with the different language and all that - I guess posting it up here gives people is a more user friendly way to show what's available on Yahoo!
https://www.sau.com.au/forums/topic/74168-want-deeeep-dish/#findComment-1363334
You are right my friend!
I have also stated this in my first posts on SAU.
As many people can't browse the Jap Yahoo auctions due to lack of language packs, or simply no time, this is where i step in and give a hand.
I see that you advertise Jap Auction products as well.
I only wish i had this avenue to go to when i was shopping years ago. :P
Wink is on the ball. cheers!
https://www.sau.com.au/forums/topic/74168-want-deeeep-dish/#findComment-1363536
No worries, good stuff :P
https://www.sau.com.au/forums/topic/74168-want-deeeep-dish/#findComment-1363555
these things are huge!!!
19" two piece forged.
****MULTISTUD*****
19x bloody wide fronts
19x even friken wider rears.
ALREADY PURCHASED AND ON THEIR WAY TO OZ.
the tyres have a mere 500k's travel time.
Dunlop LM701 235/35 fronts, 275/30 rears
Offset and PCD ill update once they are in my hands.
https://www.sau.com.au/forums/topic/74168-want-deeeep-dish/#findComment-1364766
Hey members,
I'll be adding deep dished wheel packages here regularly.
Here is something to kick things off with.
Work 19" by  a mere 8.5 inch. +30 offset. still some nice dish though.
114.3PCD 5hole
bids close 24thMay
How much for these???
https://www.sau.com.au/forums/topic/74168-want-deeeep-dish/#findComment-1365005
