  • Replies 49
LOTS!
DOHC, 4.0l 6-pack with a restricted and underloaded turbo and motor...
BIG things will be made from this platform!!
A mate just received his after a delay with the sunroof and a crack in the windscreen which was replaced before delivery.
Click here to see the professional shots he had taken the other night.
AWESOME!
https://www.sau.com.au/forums/topic/7473-new-turbo-falcon/#findComment-109400
Guys,
They wound the boost down on the turbo to prevent the power exceeding the XR8. They did this because otherwise no-one would buy the V8. I have heard it has serious potential, at the factory they pushed over 300kW at the flywheel during testing. Factory skylines come with restrictive airboxes and exhausts, to meet EPA, but it doesn't take much to replace them.
I think we are in for many years of fun racing these down at the drags.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7473-new-turbo-falcon/#findComment-109424
Apparently it has a very restrictive airbox and exhaust.
It has a restrictor on the turbo as well which can be removed. Aftermarket companies in this country are falling all over themselves to develop this car. ANYONE that says this car has no potential is not thinking straight!
It's the same as saying that, "because of the way a factory r33 ecu retards the timing when boost is increased, it's not worth developing the rest of the car". How many of us here have aftermarket ECU's?!?!?
ridiculous! not a shot at what you said, just that i'm sick of hearing bullsnot being thrown around on this subject.
Lets think about it: Change exhaust, remove inlet restrictor and other restrictions, up the boost, BANG 300kW !!!
That's potential in my book!
:D
https://www.sau.com.au/forums/topic/7473-new-turbo-falcon/#findComment-109427
I agree with 2rismo, the performance shops already have parts ready to bolt-on and can't wait to replace the engine management systems, the potential will be awesome.
Aslong as they can fix the problem of the side airbags going off, casue that would be a bitch if your racing and the airbags blew up.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7473-new-turbo-falcon/#findComment-109432
Deesh,
If you wanted a drag or race car then I would agree with you, but these aren't intended for that purpose. They are a luxury sports saloon, and therefore have to have all the goods that people expect these days.
I'm sure if you stripped it then you could loose 300+kgs.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7473-new-turbo-falcon/#findComment-109455
These cars have just over 200kw at the wheels straight out of the box. I point your attention over to this thread on performance forums http://board.performanceforums.com/forums/...readid=67137695
Very impressive. And for those people complaining that it weighs to much...go buy a mini or something.:D
https://www.sau.com.au/forums/topic/7473-new-turbo-falcon/#findComment-109561
these things DO! have a crapload of potential,only thing is that i dont think the tranny is gonna hold up to much abuse,as thereve already changed 400 auto's out of the first batch made,and even the 5 speeds are going aswell, but there are strengthing them.
Also i have heard from a mechanic that words at Fords in broadmedows in the warranty/workshop that the only problem is the crank,rods etc and to get the power out of these things and to still be reliable all these things will have to be changed
https://www.sau.com.au/forums/topic/7473-new-turbo-falcon/#findComment-109782
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
