i am shocked i wake up to
scott come here scott my mum Yelling at me its like 11
she was outside with a white Gts-t Skyline r33 outside i am like wtf is going on
I go out she shows me the car and says she found it at a dealer down the road i am Shocked for a Dealer in my shit town to have a import next i look at the price on the window thinking it will be heaps
$16999 i am shocked
Look over the car looks clean nice white body kit mags's 17's
120000ks
inside is a little worn hand brake and gear boot
it was imported in 2002
i get him to pop the hood
I find a
Big pod
Brand name front month intercooler
Turbosmart Bov
look at the exhaust and under the car
has 3" turbo back exhaust that isn't too loud which is just what i wanted
i see aftermarket Shocks and springs
Look at it i think its a M spec with bigger front brakes and LSD due to the wing caust its a 1994 with a big wing
anyway bak to my story i go inside and mum goes back to the dealer
i thing about it and go y not have a go i ring her tell him i will give him $15000
i wanting for a nah thats not right off him
he takes my offer of 15k and tells me it is off the market till i pay up gave me a week
I get 3 months warranty
i went to the bank later that day and i am buying it he has taken it off the lot i am still shocked
what r ya thoughts did i get a deal or what
from a dealer yes that is cheap, althouugh you are mistaken about a few things,
all 33 gtsts have the same brakes and LSD not just mspec.
just make sure its in good nick body and mechanically get a compression test done get someone that knows skylines to check it out it might be a rough car and u might not see it unless u know what to look for.
i know a bit about skyline and it looks fine to me
yes the day i get it i am taking to my Import mod shop that only works on Imports and they will check it over
Body is pretty good only thing is the seals on the windows and shit r going but my silvia was the same
What what All r33 have LSD do they i thought it was only M specs
yeah windscreen and rear window seals are often shit
probably best to take it to your import shop for inspection before u buy it rather than finding out any bad news (if there is any) after u get it.
all r33 gtsts have LSDs and the same brakes for sure, i have inspected about a million of them for friends buying and have had 2 myself :D
nice find man, atleast your mum knows what a skyline is, she mistook my GTR for my bro's 180sx driving down the st.
mark
:D Thats gotta hurt.
I reckon 15k from a dealer is an awesome price... gotta wonder how much he paid... :headspin:
just a question like 2 or 3  ppl said get a compression test done is this a thing thats notorious for all skylines or just the 33?? how can u tell if it needs a compression test done or if it has a lack of compression?
compression testing will show if there is something wrong with the engine, like damage or excessive wear, if a compression test comes out bad its best to do a leakdown test which will show exactly where the problem is.
any car you buy should have a compression test done for peace of mind. especially if its a turbo or hi performance car.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
