I can answer this question, i just finished installing my hks type 1 turbo timer, which has an automatic timer on it. It actually gets the countdown from the rpm, if you read up on it, it goes up and down depending on what rpm you have it on. Say u flog it for five minutes, and then sit in traffic for 2 minutes the auto timer function may say something along the lines of 30seconds. I assume u did not install the turbo timer. and i commend u on that. it was a painful job esp when u have to splice into the ecu wires :P
Does it display ur speed etc??
anyways, hope this has helped.
https://www.sau.com.au/forums/topic/75062-turbo-timer/#findComment-1378235
its not that hard to connect the other wires up, just need to have pateince, and take your time doing it to make sure its done correctly. Im surprised the automatic timer function works :s ... mine didnt until i connected the rpm sensor into the ecu. I have all the wiring diagrams if you want one just ask me.
leave ur email address on here, and ill send u the pdf file ;)
https://www.sau.com.au/forums/topic/75062-turbo-timer/#findComment-1381191
  • 4 weeks later...
Damm TT's!
I fear even adding to thread like this for fear or retrobution from yall hardcore racers Ha!
Ma only two cents, is that most of the "auto" ones ( i think) listen for a pulse on the +12v indicating fireing of coils. Most then have a facility to fine tune. So you hold the RPM at a specific point, it listens to the noise, then it multiplies this, so it knows the rough RPM at a point in time.. without the need of a feed of another signal.
- M
https://www.sau.com.au/forums/topic/75062-turbo-timer/#findComment-1462322
to answer your question re: what needs to cool down. the exhaust wheel of the turbo and the turbo charger components get very very hot under operation and even hotter under extreme operating, ie lots of boost constantly. the turbo timer allows the turbo to keep spinning as the exhaust is still going. this means the oil and water lines are still flowing so oil and water is flowing around the bearings and core to cool it down. if you just turn it off instantly the oil and water lines stop and the bearings stop spinning. its a bit of a if and um topic really you dont have to have one you can just take it easy for the last minute or so of the journey if you are driving hard. trucks run lots of heat dont use timers or anything so it should be ok in most normal conditions
https://www.sau.com.au/forums/topic/75062-turbo-timer/#findComment-1462749
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
