You should have asked us while it was in the shop Brendan :P
Place 30mm socket on pulley nut with LOOOOONNNGG bar on LH chassis rail and then hit the key...
Ooops, that's right, no wiring...
Hmmmmm
Remove Rad and get decent rattle gun...
Cheers
Ken
can't you get a rattle gun from somewhere?
i need to get mine off too somehow but the engine's on an engine stand :D
Its easy on a stand but in the car you have to remove the air cond condenser to use a rattle gun and you will need a 3/4 " gun , 1/2 " won't do it .
not a good idea to use a rattle gun if engine still in the car , you have to remove the air cond condenser and you will loose the gas !
Just use a 3/4 breaker bar and i think 27mm 3/4 socket for your gts .
