Finally run a half reasonable time
12.1 @ 111mph
but i have a question... last time with 200rwkw i ran a 12.90 with 200rwkw or there abouts.
now im up around the 300rwkw.
My time has gone almost a second up, yet my MPH hasnt changed one skeric really. Any ideas why that is?
I made a nice 1.90ft, same as my old 12.9 run was.
So they were pretty similar, jsut the times changed :headspin:
https://www.sau.com.au/forums/topic/75175-finally-a-decent-time-and-a-q/
At Heathcote i was running 12.7@111 and i have around the 235rwkw mark. What was your half track speed? Should be around 87mph. Something sounds a miss even with a 1.9 60'. Are you sure you werent shutting down just before the line, Ive done that before.
What mph was your 12.9?
12.1@111mph you must be getting of the line pretty quick!, i only ran 12.4@112mph when i went - and i have 4wd launch!
oops, it was 109mph, and id run 110/111 just for times of 13.00/13.10 etc
my 660ft times was 9.3/80.7 mph... i wasnt backing off thats for sure.
I kept my foot in right past the little white checkers :rofl:
i went easy on the launch as the cars just burns the tyres if i try a decent one
There is something wrong with that 660' time, your at least 1.0 off the pace and 8mph. Check it with your other runs at the 660' mark.
correction, stoopid a$$ me looknig at the wrong sheet
660ft was 8.00
mph/660 was 94.8=68
It has way more than it did wheni ran a 12.9, i seriosuly doubt there was another second in there back in its old form. I've changed nothing traction wise at all.
If anything the tyres are a bit older and crappier now than they were a year ago (12.9 @109mph/200rwkw)
I know the problem. :P
Well m yguess anyway is that the clutch was starting to struggle in the top gears, and what you though may have been wheelspin into 2nd nd maybe into 3rd was actually the clutch starting to give up...well perhaps a combination of both.
That night at Clader where you chopped me my clutch was getting worse with every run, by the end of th enight my mph had dropped 3-4mph when only running approx 200rwkws.
Anyway food for thought:)
with the power you claim your trap speed is way down might be an idea to run it up on a dyno just to double check maybe you have a problem ?. Your abit slow to the 660ft mark and you mph is down thing is your 60ft times aren't bad at all .
For whats it's worth I know my car is abit of a differen't kettle of fish but I have one of the slips here for a [email protected] and on that run went
660ft 7.837@91mph with a 1.8 60ft .
Also don't be fooled into thinking peak power dyno read outs are everything can you tell us abit more about the car and mods .
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
