Finally run a half reasonable time
12.1 @ 111mph
but i have a question... last time with 200rwkw i ran a 12.90 with 200rwkw or there abouts.
now im up around the 300rwkw.
My time has gone almost a second up, yet my MPH hasnt changed one skeric really. Any ideas why that is?
I made a nice 1.90ft, same as my old 12.9 run was.
So they were pretty similar, jsut the times changed :headspin:
https://www.sau.com.au/forums/topic/75175-finally-a-decent-time-and-a-q/
At Heathcote i was running 12.7@111 and i have around the 235rwkw mark. What was your half track speed? Should be around 87mph. Something sounds a miss even with a 1.9 60'. Are you sure you werent shutting down just before the line, Ive done that before.
What mph was your 12.9?
12.1@111mph you must be getting of the line pretty quick!, i only ran 12.4@112mph when i went - and i have 4wd launch!
oops, it was 109mph, and id run 110/111 just for times of 13.00/13.10 etc
my 660ft times was 9.3/80.7 mph... i wasnt backing off thats for sure.
I kept my foot in right past the little white checkers :rofl:
i went easy on the launch as the cars just burns the tyres if i try a decent one
There is something wrong with that 660' time, your at least 1.0 off the pace and 8mph. Check it with your other runs at the 660' mark.
correction, stoopid a$$ me looknig at the wrong sheet
660ft was 8.00
mph/660 was 94.8=68
It has way more than it did wheni ran a 12.9, i seriosuly doubt there was another second in there back in its old form. I've changed nothing traction wise at all.
If anything the tyres are a bit older and crappier now than they were a year ago (12.9 @109mph/200rwkw)
I know the problem. :P
Well m yguess anyway is that the clutch was starting to struggle in the top gears, and what you though may have been wheelspin into 2nd nd maybe into 3rd was actually the clutch starting to give up...well perhaps a combination of both.
That night at Clader where you chopped me my clutch was getting worse with every run, by the end of th enight my mph had dropped 3-4mph when only running approx 200rwkws.
Anyway food for thought:)
with the power you claim your trap speed is way down might be an idea to run it up on a dyno just to double check maybe you have a problem ?. Your abit slow to the 660ft mark and you mph is down thing is your 60ft times aren't bad at all .
For whats it's worth I know my car is abit of a differen't kettle of fish but I have one of the slips here for a [email protected] and on that run went
660ft 7.837@91mph with a 1.8 60ft .
Also don't be fooled into thinking peak power dyno read outs are everything can you tell us abit more about the car and mods .
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
