Hey,
Ive done a search on this subject but couldn't find anything.
I've come to a fork on the road with my skyline. Do i get a Power FC or not?
Currently i have on my RB20:
185rwkw @ 1bar
R34 GTT turbo
Walbro 255 pump
Filter
Bov
2.5 turbo back exhaust
Apexi EBC
Trust V-SPL FMIC
Chipped/Remapped ECU with maps for R33 turbo
If i install a Power FC how much power will i gain?
Is it worth spending $2000 to buy/install/tune?
Any help would be lovely :rofl:
Cheers
Sean
https://www.sau.com.au/forums/topic/75198-to-pfc-or-not-to-pfc-rb20/
How you will gain will depend on how well the stock ecu has been remaped.
You most probably won't gain anything up top, maybe a little as it will be able to tuned a little closer to the edge as the PFC has a knock sensor readout.
Mid range is possibly where you will pick up some power, but once again it depends on how well it was tuned with the stock ecu.
I would probably stick with what you have now if you are not planning on upgrading the turbo at a later date.
what an idiot, i know that you will only get a few kw's to begin with but if you continue modding it will be the thing letting u down in the end!
Hey...idiot is a bit harsh:)
I think the previous owner was looking for an improvement whislt keeping it nice and quiet, ie not drony:)
narc up boys, i would like to know aswell because i just purchased an rb20det power fc for $1099 my 32 has high flowed turbo, hks front mount, 14psi, bosch 040, 3.5inch exhaust all the way through, either gtr or rx7 550cc injectors will be going in soon, and going to get it tuned at 18psi...have never had the computer tuned so hopefully it will have stacks more power when i get it tuned...hoping around 40-50hp...let us know what u think
If you want the extra 40-50hp your gonna need the stroker crank i just bought. Its custom made from a crew of brilliantly gifted engineers in the former Soviet Republic...liek the GTRcrank it will need some clearancing of the block, but she will make the power im after:thumbsup:
http://www.bath.ac.uk/~ccsshb/12cyl/rta96c_crank.jpg[/img
...lol as Cubes said, depends on how good your current tune is i suppose:)
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
