Greetings,
I know there are quite a few people out there who have built their version of an RB30DET and im interested to know what parts you ended up using and what work you all had done to the enigne. Turbo sizes, cams, what head etc.
Pictures would be nice too! :wassup:
Thanks for your time,
Scribble
https://www.sau.com.au/forums/topic/75216-your-rb30det-build/
well lets hope some people reply for you then.
but the people on that thread have stated it over and over and people keep asking the same thing 101 pages later cause they don't want to read it and they have stopped trying to help.
if it helps you at all, WHEN... I do my one.
it will be stock rb30 bottom end with the pistons that are in there....
new rings.
stock rb25de head... tested
stock rb20/25 exhaust manifold.
some turbo that will make close to 500hp at 1 bar. and with a 1.03 rear so I can actually drive it without frying the tyres.
Add intercooler, oil cooler, PFC, GTR injectors, fuel regulator (if required),
that is all in terms of MOTOR mods.
not that it helps you but I want to do a budget one and see what I can safely get.
and I'm quite certain it will be a lot moe driveable and safe than a modded RB20 that will come with the car.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
