Before any1 gets upset, I have searched here, and on SDU, and haven't found the info I'm after...
I have recently put some RaceBrakes RB74 pads in the front. The squeel like nothing I've ever heared before once they have warmed up!!!!
Below is what precautions I took to ensure they dont squeel much, and also things I didnt do...
I transfered the shims from the old pads over....
I put some of the pbr glue for brakes on both sides of all shims, and on the pistons of the outer half of the caliper. Unfortunately the pistons on the inner half missed out b/c I couldn't get to them...
I was told to bed the brake pads in by doing 5 - 8, firm 100 to 60km/h stops to begin with... but I put them in on a Sunday night, as the old ones were wearing thin, and I didnt have any time to do this until a week later....
So my question is.. is there anything I missed, or anything I can do now, to stop this horrid noise from haunting me??? I'm too embarassed to press the brakes sometimes, as the noise is ear piercing.....
Zahos
https://www.sau.com.au/forums/topic/7523-more-questions-on-brakes/
Guest GR33DyMANGO
Zahos
yer i get that high pitched squeel aswell. i asked my uncle (whos a mechanic) how to fix the problem when i had my last car and im pretty sure he said there was something u could buy which you apply to your brakes the problems solved instantly. sorry i cant remember what the stuffs called, but im sure i;ll be chasing it up soon.
anyway, id phone a local auto store and ask if they sell any products that fix the problem.
Yeah, that is the brake adhesive I said that I put on... although I didnt out it everywhere...
Below is a pic, detailing the surfaces I cleaned, and put the brake adhesive (anti squeel onto). For the outer brake pad, I did every surface. For the inner brake pad I did every surface EXCEPT for the pistons. Will this make a difference? If it did, then I dont think if would squeel this loud, as the surface the pistons touch, did have brake adhesive applied onto them...
Does any1 believe it is b/c I didnt bed the pads in like I was told to???
I had the squeeeeeling,
this was after i got the pads changed to ebc street kevlar
then i went back to the brake joint, cos it was making too much noise. this is rear right by the way and then they changed it to hopeless bendix pads in the rear and the squeeling has stopped alot, though now it is very very barely noticable, can hardly be heard
dogs hate me though, haha
apparently it was something to do with the brake material and not enuff rear weight in the vehicle. i gotta go bck though cos i like the ebc's better, and oh yeah the discs have been machined twice in the back.
good luck, but i would really check the pad compound
I run RB74s on the front too, and yeah, the squeals are ear shriekingly loud sometimes :) I don't mind too much though, theres always a trade off when choosing pads.
How do you find them in other respects? I like them a lot over the Ultimates they replaced.
Braking power is excelent, but the noise I can live without!
Did you bed them in as soon as you installed them? I was told to do 5 - 8 HARD stops from 100-60 to bed them in, otherwise they develop some sort of glaze...????
I didnt do this until 1 week later!
Have you tried the adhesive as well???
How long have you had them in??
Sorry about the bombardment of questions, but they are really starting to annoy me....
For the money RB74 are at, you can't complain much. Noise is the draw back of having a pad like that. If you hate the noise, stay away from racebrakes Comp 9's. They're the best pads I've used so far.
RB74's last longer than comp 9's, but comp 9's brake that little bit better at very high speeds. I find the RB74's better than the green stuff, but it's noisy and heaps of dust. For the circuit, RB74. For street green stuff.
Endless NAM, absolute crap!
Well, it isn't that you haven't bedded them in correctly, that shows up as really poor braking performance. If you didn't do it for a few days that hyst means the resin was on there a few extra days on top of the months it was in the box.
Could just be that they are noisy pads - some are MUCH worse than others.
Originally posted by slip
mate im gettin rb74's.  can you give me a bit of a review of them?
Sure..
They grab VERY well compared to the standard nissan items, and bendix ultimates (haven't tried anythinf else myself). So far (in the 1.5 weeks I've had them) I've noticed that they dont fade as they heat up... and they perform very well at high speeds (I managed to lock up my front wheels at 160km/h).
But the only draw back is the noise (which I cant stand)!!!!
So if you want some, you can buy mine if you like (I've had them in 1.5 weeks so far, street use only). They are virtually new, and I'll knock a fair bit off the price too!
I didn't do 5-8 hard stops but I think my usual driving style would have bedded them in well.
I haven't tried adhesive although I was thinking about it. It didn't make any difference for you so I'm not sure if I'll bother.
I've had them in since the 1st week of September and they've taken a decent amount off the rotor. I'm pretty sure these chew the disc faster than Ultimates, but that could just be me threshhold braking too much. Would have been difficult with Ultimates because they fade so much faster. :)
These pads are great at doing their job, but next time around I may try a slightly less harsh compound (on the ears and the rotors) from RaceBrakes for street use.
Remeber... I didnt put the adhesive on all surfaces, and I'm not sure I let it al dry properly....
I'm starting to think that it only happens on my drivers side, so the adhesive may have helped...
I am taking it to racebrakes monday to get my discs machined, and I will see if they can put the adhesive on for me all over.
Will let you all know if it makes any difference...
