FEEL FREE TO V0ICE YOUR OPPINIONS based on experience and or here say.
I'd like to Know if the rb 30 has any benifits that may assist in drag scenario in an 32 GTR. I have heard that they produce more torque but do not rev as hard as aRb 26. Is the block as good, crank stronger, these are just some questions one tends to ponder.
I am concidering the fact that rather than modifying my rb26, it maybe benificial to buy an rb30 with some of the work already done on the bottom end and bolt on my head and periphrals.???hhmmmm.
Do they fit into an R32 gtr easily and what differances in fitting may one come across. :headspin:
https://www.sau.com.au/forums/topic/75284-rb-30-versus-rb26-performance/
It doesn't cost more to build a RB31DET, it costs much less if you take into account the original cost of an RB30 versus an RB26. The reality is if I spend the same money buying and modifying an R32GTST, as I do buying and modifying an R32GTR, the R32 GTST will be faster. Ultimately, if I have enough budget, I could get the R32GTR to be faster but it would need to a pretty BIG budget
Taken from http://www.skylinesaustralia.com/forums/sh...&highlight=rb30 regarding a budget of XYZ dollars rb25/rb30 vs rb26 comparsion thread
As you have specified a drag scenario, here is what I've read, seen and experienced.
If you take a properly prepped 2.6 and compare it to a properly prepped 3.0 you will find that the 3.0 can actually rev quite high. I've seen them rev out to 9000rpm. My prepped 2.6 revs out to 9500 but we set the limiter to 9000 for safety reasons.
The 3.0 will make more torque. There's no doubt about that. Nearly every aspect of the 3.0 is superior to the 2.6 but it will cost a lot more to build a strong 3.0 overall package simply for the fact that the torque created by a 3.0 will break things which a 2.6 won't.
My 2.6 runs stock diffs and driveshafts. A big HP 3.0 will snap these things like twigs on a hard launch due to sheer torque.
If you look at the RacePace Motorsport 3.0 GTR (owned by RPMGTR on these forums) you'll find that all his driveline are aftermarket or custom built to deal with the torque created by the 3.0 engine.
We've launched my car at 8500rpm with 617rwkw and there was no problems on the stock driveline. Doing the same on a 3.0 is a recipe for disaster IMO.
If you put the same turbo setup on a 2.6 and a 3.0, you'll find that the 3.0 makes the power a lot easier too. This is simply due to displacement. My turbo put on a 3.0 setup will make the same power as me with less effort. I reckon it'll make the same power as my car bout 1500rpm earlier but that's an educated guess as I haven't had the chance to compare it.
The simple answer is look at Kier Wilson and John Munro. Both run the OS Giken 3.0 bottom combined with a custom driveline. Kier has run 8.7 (slicks) in his 3.0 and John ran 9.2 (Nittos).
Drawback of the 3.0 setup? Cost. To prepare a 3.0 car including gearbox, clutch, diffs, driveshafts, bottom end prepping and an appropriate turbo setup, I'd say you'll be very light pocketed when yr done.
Hope this helps.
Leewah, much appreciated in put. The torque factor is a major concideration, i didn't realise it was so crucial in relation to the drive train. I would prefer not have these problems and i think i might stickwith my 26, hhmmmm not sure still.
Could you shed some light on the gear box "beef up", is it not 3rd gear that gives all the trouble, can one not simply replace 3rd with a better quality cog ?? Wht is the better way to go, please?
Dave
Hope this helps.
The torque factor can be seen as both a blessing and a curse.
Sure, with the 3.0 you produce huge amounts of torque off the line and the car will continue pulling hard until you take your foot off the loud pedal but at the same time, it adds a large amount of stress on the gearbox and driveline.
Generally speaking, from what I've heard, it is 3rd which tends to break in racing. This is due to the fact that 3rd is where most of the power is made. The other factor is also how you change your gears. The Garage Saraus R33 GTR used to run an OS Giken Cross Mission gearset (like my car and the RPMGTR) and ran 1200ps. I'm sure they broke gears but I also know people in AU how have snapped gears in a Hollinger like toothpicks. If you are rough on the gearbox, it will break. On the other hand though, I've known people to break their stock gearbox in a 300rwkw GTR. Treat it like you would like to be treated and it will last.
Sure you could replace gears everytime you break them, but at over $1k per gear + labour, it gets expensive after awhile.
Don't let me discourage you from doing a 3.0 project. It is a field which is becoming more and more common these days. The results of a properly prepped 3.0 will be great and very rewarding. I chose to go down the path of the 2.6 as I felt that I wanted to keep some aspects of the GTR intact when I raced it.
Cheers,
Dave.
Dave
VL bottom ends are fine as long as they are prepped properly.
I beleive the RPMGTR uses a modified VL bottom end.
At the end of the day, it is a Nissan item :D
Hey Guys
would a rb30 bottom end be reliable enough to make 1200ps?? One out of a VL or something like that not the OS Giken kit.
It's a numbers game............and there is always more than 1 number....
A 600 rwkw at 8,000 rpm 3.1 litre will have the same torque as a 600 rwkw at 8,000 rpm 2.6 litre. Remember horsepower X rpm / 5250 = torque.
So the only time you have a 3.1 litre with more torque (and the same horsepower) is if it develops that horsepower at a lower rpm. Similarly it will develop the same torque at lower rpm, and lower launch rpm means less stresses on the engine, the gearbox, the clutch the diff etc. Lower shift rpm = less wear on the gearbox as well.
It is average torque over the used rpm range that propels you down the 1/4, so a 10 sec 2.6 litre will need the same amount of torque as a 10 sec 3.1 litre. If you have a 3.1 litre that makes more torque it will be faster, therefore you are no longer comparing two 10 second engines.
If I want to do 10 seconds for the 1/4, I serously doubt that there is much difference in cost between an 2.6 and a 3.1 litre, except you won't have to rev the 3.1 litre as much to do the same time. So it will last a lot longer, 20% lower rpm = a lot longer between rebuilds. Plus I can buy a rebuildable RB30 bottom end for $100, try that with an RB26.
Based on the above logic, I reckon a 3.1 litre is goping to work out far cheaper.;)
why not try talking to rob ward of rotorua import performance shop (rips) in nz. afaik he does 10.5sec passes all day every day on a stock rb30 bottom end with rb26 head in a gts 4. the skylines downunder site has some rips cars on it - at least one i've seen has the username 'bradyz', it's a purple gts4.
as for the fitting issue the rb30 thread has it all...
Gentlemen , thank you for you input, all your comments are sincerly appreciated.
I AM GOIN THE RB 30 --------- YEAH!!!!! :flamed:
AN rb30 will work out cheaper but only marginally but the beauty is the availablilty of important thangs like block cranks and girdles as opposed to the rb26. IF you want to send me a PM if you are serious I can discuss some mods that i have done to my own rb30 in my GTR to make sure it will rev to 8000RPM all day everyday, and remember 8000RPM in a rb30 is the same cubic displacement of air as an rb26 and 9600RPM.... I am currently building two other rb30's to go into r32 GTRS with all different combos and end needs for the engine so PM if your keen. Oh by the way I make the spacer plates to adapt the rb30 to the rb26 sump....
That said, is it actually worth the ~25k for the OS Giken RB30 Kit? and the ~15k for the OS Giken Gearset?
If you can afford it, hell yes. It's all a very nice kit.
Try for a OS 3L and OS sequential though :rofl:
The OS kit is far stronger and has been known to last a long time with over 1000HP.. thats pretty impressive if you ask me.
GTR32: Robs 10s GTS-4 only ran a stock RB25DE head.. also a stock GTR gearbox.. which has held it back from 9's.
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
