Hi
Currently I have 17inch rims with 235/45/r17 tyres (Nankang, hehe) and need to replace them as the tyres are causing steering wheel vibration at speeds over 110km.
I have come up with 2 options, which is 'better'
option 1
Buy 4 235/45/r17 quality tyres such as Dunlop SP3000, Michelin Preceda or possiblay SO3s
option 2
Get 18 rims 8.5" at the front and 9.5" at the rear with Hankook Venus Sport "K104" rubber. 235/40/18 front and 265/35/18 rear.
These rims will make the car look better too
Which option will give me better performance???
https://www.sau.com.au/forums/topic/75381-tyre-quality-vs-size/
check out the maxxis victra in 235 /17 sold by bob jane. came out very well in the recent motor (wheels?) tyre test that included ost of the big name brands and tyre types, and half the price of most of them. 4th overall and there was nothing in the diferences really ie .06 sec through the slalom etc
And thats not a lot???
For my 10 cents worth you are much better off spending your hard earned on a better set of tyres rather than set of larger tyres. The most marked difference will be in the amount of wet weather grip the tyres have - ie grip when you need it most.
By and large there are cheap tyres & there are good tyres.
If you want a set of 18 inch rims for looks then that is a completely different argument. Remember though, that for an equal quality rim a 17 inch set up will be lighter than an 18 inch. If you end up with a cheap 18 inch rim then it will be much heavier - to the detriment of your ride & handling.
ummm...under the circumstances no, i don't think it is. we're talking six hundredths of a second slower, such a small amount of time that on any other given day it might have been six hundredths faster. i think that's bugger all. sure if you're trying to shave tenths each lap it's considerable but we're talking a $200 street tyre here. if you can justify spending twice the amount for a street tyre that's .06 sec quicker then either $ don't matter, you are always able to drive at warp speed or you need to drop your card to ferrari. the victra beat most of the better known brands in a lot of areas and all of them in others such as wet braking, which i'd have to say is pretty important in terms of keeping my car and hard stuff away from each other on the street where there are no run offs.
for some reason the noise test, in which the victra did very well, wasn't included in the points score. if you saw how close the overall results were you can't help but wonder why the noise result was left out of the points score.
i simply reckon they're worth a try on the basis of the test results.
cheers
cheers
:werd:
I read that test and it looks like that tyre gives by far the best bang for buck performance out of the group.
would be good if someone who had them could report on just how long they last as i think they could be quite a soft compound?
:werd:
Hi Interloper;
my thoughts exactly, not sure about the wear but I've had Yokos go hard after about 60% wear so who knows. but at about $200 per tyre it's a chance i'm prepared to take.
Regards
Hi Interloper;
Regards
i will be after some in the near future, so let us know what your thoughts are if you end up buying them.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
