Guys,
I have the below listed RB26 engines for sale
1) 1997 Series 3 R33 GTR Engine. Complete with ecu,harness etc has done 65,000kms SOLD
2) 1989 R32 GTR Engine. Engine has done 100,000kms and has damage caused by the fire which burnt the car. Engine is a long engine it also comes with turbos, oil pump it has no fuel rail, injectors, ecu, harness. $2500ono
3) R32 GTR Gearbox has done 100,000kms looking for $800ono
4) R32 GTR Intercooler slight damage but still good $500ono
5) R32 GTR Fuel Pump $200
6) R33 GTR FUel Pump $300
7) R32 GTR Brakes complete with discs (front and rear) $800ono
9) R32 GTR Diff SOLD
10) Rear subframe less diff, drive shafts and brakes. Great for a circiut drag car that has a cracked one. $800 ono
Guys, there are also other parts available, please note that the interior and panels are all gone (burnt) so only mechanical parts are left email for details
Guys once the R32 GTR is stripped i will arrange pics. For more info email me [email protected].
PS: Willing to send interstate if the buyer pays and arranges for pickup by freight company
https://www.sau.com.au/forums/topic/75392-rb26-engines-and-parts/
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
