Hi,
> Can some one please tell me what Garrett turbos I can use to upgrade my 1993
> R32 Nissan skyline GTR Twin turbo that are a direct bolt on fit?. I
> think the car has T28 standard bushed turbos.
> I would prefer turbos with ballbearings flowing 300+ hp each and capable
> of handling 1.2-1.4 bar.
> I have been told from a local mechanic in A.C.T that a garrett GT28r and the
> GT28rs (disco potato) will fit and bolt directly on.
> I have also been told from another mechanic that the GT28r and rs wont
> bolt directly on to a standard skyline and will need certain things
changed but a hks g2530 will bolt straight on.
> Is there a t28 Ball bearing turbo direct fit made?
My engine has just been fully rebuilt with forged pistons , shot peened rods with heavy duty rodbolts and ported and flowed head with the rest of the internals being stock but new.
> I appreciate your time and help.
https://www.sau.com.au/forums/topic/75967-bolt-on-upgrade-turbos-r32-gtr/
Barneys GTR has N1's and not a lot else and goes great.
No lag, full steel and with the right setup are able to make 600 ps in Japan.
All yours for the bolt in price of $3000ish for R34 N1's
PS Michael - 2530's are rated at 320hp each and should be good between 1.5 to 2 bar.
Sorry for the late reply, I ended up buying a set of Garrett GT2560R Ball bearings turbos as these will bolt straight on and fall in my budget range of $3000.
I have been told by a garrett dealer that these will bolt straight on and flow up to 400 HP each at 1 bar and have a steel exhaust wheel. They are cabable of 1.8 bar max.
I could not get a set of HKS 2530's or N1 's in that price range, equal to the same performance as the GT2560R..
The turbos that were pulled of the car Seemed to be a Garrett T28 ball bearing hybrid turbo. These are in as good as new condition with zero end play and are for sale if you know of anyone interested. (they have been inspected by a mechanic and I was told they barley have done I000-3000 km). they have a ceramic exhaust wheel and are only cabable of handling 300HP at 1 bar max. hence the reason I am up grading to the GT2560R.
I have been told by the engine builder that the car should produce 400 + RWK with the addition of a power Fc, boost controller, 550 injectors, high pressure fuel pump and bigger intercooler
Thanks for the help
  • 3 weeks later...
Thanks for the help
Hey Mike, I am going through exactly the same process.
Am thinking about GT-SS or the GT2560r like you.
I understand that the GT2560r more or less IS the N1 turbo and I have also heard that the GT2560r IS the GT28RS (disco potato), Garrett implemented a new naming scheme apparently.
anyhow, back on subject. How did it go? Do you have them fitted? And most importantly what is their response like?
I am after quick spool up and hence I am looking at the GT-SS also.
Matt.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
