Quick question,
For a while now I have thought I have had a dodgy knock sensor. After doing a bit of fiddling with the fuel and ignition maps on the weekend to fix up a bit of knock, I noticed my PFC hand controller is indicating knock when ever my diff locks up ( 1.5way mech.)
Has anyone else noticed this? In a straight line I was getting up to 70 knock on the hand controller, after a bit of playing around I got it down to 35, which I think is acceptable
On my way home driving through the hills, I would glance down and see 60-70 knock again, and upon closer inspection it was picking up knock when my diff locks up out of corners?
Has anyone else had the same issue?
Chris
Not me but id say,at a guess,that your diff is taking initial torque and your engine is under a stress lock momentarily.All this would come about because where teh tyres used to spin before letting the engine breathe a little b4 it now cant.
Babble!maybee.Never know it could be somthing else not the diff.But if it happened like it did when you say it did then it more than likely is the diff that is causing the knocks.
Not me but id say,at a guess,that your diff is taking initial torque and your engine is under a stress lock momentarily.All this would come about because where teh tyres used to spin before letting the engine breathe a little b4 it now does not under certain loads.
Babble!maybee.Never know it could be somthing else not the diff.But if it happened like it did when you say it did then it more than likely is the diff that is causing the knocks. :confused:
^^ what he said.
i guess your getting that little bit extra grip, before it lets go maybe?
Mine was tuned with my new diff at the same time so i have nfi!
but then, that (you would think) wouldnt matter on a dyno in 4th etc ?
interesting too see what comes of this thread indeed!
Its odd hey!
The problem is my PFC and Diff went in at the same time, so I can't compare too!
It seems strange though, as even when its not under and load, the clunks from the diff show up as knock? I have aluminum sub-frame bushes, as well as alloy tops on my suspension, I wonder if the noise is travelling through and reading as knock. Its quite loud in the car around corners etc
Bit of a wierd one!
I would posibly be load from the inside wheel and outside wheel trying to go round at the same speed, but it wouldnt be whenever the diff its self it locked up as that would happen at anytime under load, and therefore would show up on say a dyno or just straight line.
It could be a bit of a wild guess, but it could even be a fuel pump/tank/something else problem, and say the fuel moving about, or a bit of a connection or something is coming loose while cornering, and the jolts from the diff are just making it worse. As I guess less fuel would also cause knock correct? And that with the increased potential load would cause more again.
Id say if its a worry the car might be too much on the edge of the tune to start with.
Hi Chris,
Everytime my Commander registers a knock level above 15, it's between gears & off-throttle.
So I suspect my knock sensor is picking up drivetrain noise also. I'm not sure where it's coming from, but I think you may be on to something. Any tuners out there know what's up ??
a knock sensor is just a piezo microphone basically so it can certainly pick up driveline noise as well as just engine noise.
on a standard car with a standard ecu it is calibrated to tell the difference between detonation and other background noise frequencies.
once you change parts from standard its possible to introduce frequencies into the system that the sensor picks up as detonation, when it may not be.
i had my FC tuned before i put my super-clunky 2-way diff in, but the clunks never register knock to my knowledge. Especially on slow speed tight corners the clunks are very abrupt and shake the car around, but no knock. I also have the same aluminium cradle bushes.
I had a problem with spontaneous knock and thought it might be the sensors, but it turned out to be simply bad fuel. Try some mobil synergy and see if it makes any difference?
Funny you should say that, I have always run BP, and put some Mobil in last night becasue I was almost out, it doesn't seem to be as bad. I think its just a coincedence though, as I have run mobil before and 100 octane fuel and it does similar. A bit of a placebo effect I think :P
Still reckon the knock sensor is a bit dodgy. I reckon the guys are onto something with the drivetrain noise, my gearbox is getting old and has a bit of slop in the gears, so maybe its picking up that?
Either way, just ignoring the knock sensor for the time being, I know its not a tune issue
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
