it is at oxford square, so one of the closest is crown street. :)
anyone got tips on where to park?
Anyone in this thread entering Show 'n' Shine, Shonen, Moanie, Chard, damuscat? if your not entered i will make you ! Moanie exempt.
MAKE ME!!! :)
my car has been keyed several times and looks uggllayy at the moment.
car will become a show pony once I grad at the end of year so ill definetly be there next year :)
  • Replies 133
it is at oxford square, so one of the closest is crown street. :(
umm.. well is there a category for most stock looking car? That's probably all I have a chance of winning!
Just to throw up another idea since we seem set on japanese this month. I have just been to Masuya which is a japanese reastaurant in Oconnel St (near Govenor Macquarie tower). Excellent food. I would go out on a limb and say even better than Hikaru. plus down that end of town is a tad less dodgy for parking that darlinghurst (note i did say a tad).
I think this place would suit us well as it's quite large, has a bar too (sushi bar i mean) and they serve all the good stuff. squid leg sashimi, yakitori, tonkatsu (v. good), chicken terriyaki, tempura (v. good), all types of sushi, all types of sashimi etc etc.
hahahahahahaha....
I was reading the list asking myself: "R31girl?!?! Who's that??? Hopefully a hot chickie..."
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
