I just rang magic and mentioned that someone was dishing their product. They said these claims were 'bullsh1t'. I also asked if their product would pass an epa test and they said it would.
Im certainly not saying that this puts the argument to rest, i just thought id post up what they said in regard to these claims. I wasnt going to ask for proof or anything like that because i believe that we, as customers, have a right to expect that the claims of a manufacturer are substantiated; ie, that a cat actually performs as a cat. If i find that it doesnt when i get an epa test done, ill take it up with magic then. Ill continue to use a magic cat until i am convinced that the above claims are substantiated.
I just want to stress, that although i organised the group buy with magic cat, i have no afilliation with them at all. I just thought if i could get a better price on a cat that i needed, i would.
I did, however, get the feeling that there was some 'history' with magic and catco when i rang them. They mentioned that they knew of someone from catco who was denegrating their product. I dont know if Btmbl is afilliated with catco or not.
Shaun.
  • Replies 162
Shaun.
Hmm very interesting thread.
BATMBL
If it true what your saying, then do you have factual proof of it? Like were you there when 1 of the Magic cats were dismantled and checked?
I just did a chem exam a couple of days ago a part of which was based on catalysts. I thought I might be able to elaborate on SK's post before.
For now, without thinking about catalysts:
When you have the Nitrogen oxide and carbon monoxide turning into carbon dioxide and nitrogen and oxygen. Basically, these reactions can take place without a catalyst such as (platinum, rhodium) if the right temperature (really f&*ckin high) is used.
The reason for this, is these reactions have whats called an 'activation energy' where the molecules need x amount of energy before they can break and form new compounds (C02, N2, 02). To reach that activation energy, for these reactions alot of heat is required.
A catalyst lowers the activation energy required to break the bonds within the molecules. Eg, less heat is required to form the products (C02, N2, 02). Catalysts lower the activation energy because they are slightly attracted to the C0 and N0/N02 molecues. So this slight attraction causes the C0 and N0/N02 molecules to collide with the catalyst. Upon collision with the catalyst, the bonds between the C0 and N0/N02 molecules are weakened. Because the bonds within molecules are weak, LESS energy is required to break them.
So this means that the addition of a catalyst will make the converision of C0/N0/N02 to C02/N2/02 possible.
So what SK and lucien said before is right, without the coating (of platinum or rhodium or aluminium oxide (there was another also)) of a catalyst the exhuast gas won't be converted into the less dangerous emmisions. And emmision-wise, your exhaust will probably be as clean as one with a straight through pipe...
my 2c :cheers:
sydneykid,
right on the ball there. those materials (which cost $$$ e.g. platinum) need to be coated on the steel mesh. ceramic honeycombs are composed of this already, not coated.
anyways, i know that he would have said something like that to you Shaun, as if he would say anything else to a customer. it also wasnt me, as i havent met him or spoken to him.. i will find out whether i can get a hold of these failed test papers of the magic cat and will post on this thread. im quite sure there was testing done with these cats (along with others) recently, and it failed miserably. i sell catco products because i believe they are excellent in quality, design and pass emissions test. the new catco cat, which has the exact same insides (but coated mesh) and an even bigger body (5" not 4") would flow even better than the magic cat. so you will notice the same or even better flow characteristics on the dyno as the magic cat.
its quite simple anyways, it can all be quickly resolved if he can provide evidence of the emissions passing on that specific cat and the appropriate papers. we have got a third party to request them on our behalf and have been waiting for them for a few months now....even after several calls from the third party...we know we wont get to see them because they dont exist. why? because you cant get approval papers for a cat that fails...!
sydneykid,
Be very interesting to see how this one turns out, but if it does appear that there doing the dodgy with there cats and they are not passing an epa test then they will have a lot to answer to than the very angry and pissed off customers, they will be the least of there problems :confused:
Could someone not just look into their Magic cat and see if the stainless steel mesh is coated with something? I know it wont be proof that the cat would pass or fail an EPA test but at least it would put the rumor that the cat isnt coated at all to rest.
coating is not visually identifiable :)
I think we need for more scientific inspection on the cat than a visual one.
yep, and im sure that the way this thread is going that it wont be long before someone does something along the lines of inspecting a MAGIC cat. If it wasn't so close to the weekend and i didn't live so far away i would buy one just to get it inspected so i can see if people are getting ripped off there hard earned money or if this is just some talk going around again???
I think that after reading some of this thread a specific posts that its not the later of the two :confused:
hi guys
i the end, im not the one that needs to come up with the proof, even though i would am working on getting papers with the proof.
as an e.g. if someone has made a claim against me and i know its false, i will provide the evidence needed to put the matter to rest. the fact that the evidence isnt provided, and as 'grandmasterb' has also pointed out after calling magic himself, he keeps avoiding and turns around the and doesnt answer the question for the main reason he called...
another way of putting it is if someone claims that my name isnt michael (which it is!), but they say, no its john. how can i put this matter to rest? its up to me to prove that my name is michael by showing a birth cert or whatever is needed... not having the other party to search for records etc to show that my name is john and not Michael... i mean if you are innocent, prove it? its much easier to end the issue...
this may have confused some people, but i think you get my drift.. it would be great if i can get a hold of these papers (working on it) for proof, but there really is no need to if he has his approvals, it would really be something that Magic can settle quickly if they were in the right instead of beating around the bush not being straight with answers and just talking crap about a 'feud', when all he needs to do is go to you guys that call, yes come around or yes i'll fax you the papers, here is the proof that my cats pass, end of story...", these docs arent top secret and can be made available to anyone at request. obviously no one would ever ask for them because they expect that what they are buying is what it is claimed it is.. people can be ignorant.
i noticed a previous post about 'why a company would be stupid to attempt a thing like this', but if you really think about it, it happens all the time...what would make you so suprised that a small company in the auto indusrty is never likely to rip people off? afterall, how many people do you think know how cats work and what is needed on them in order to work properly?
also with regards to the 'how can you tell by looking at the cat', there is a way, not by looking for the coating, but by the 'stamp' of a number which indicates the caoting performed..these cats with these biscuits start with a 9(i think) and by the top of my head, the catco cat has a 4 or 5 digit number which indicates the coating used. the above statement is maybe not that useful, but any 'stamp' on the biscuit should indicate some sort of coating, but it doesnt mean it contains the right coating, as there are different specs for different cats, thus different numbers.
hmmm, maybe the way the magic cat actually passes emissions is ...by magic? lol
Mate, i disagree wholeheartedly with what you have stated above. If you are making the claims; serious allegations that can quite possible ruin a business and families involved with this business, it is your responsibility to back these claims up with conctete evidence! So far, all you have provided us with is some sh1t about biscuits and coatings. No back to back tests, no epa documentation, how do we know you're not some quackpot loser muthaf*cker just doing this for a laugh?
Also, id be careful if i were you because if these claims are false, and as you have been denegrating Magic Cat publicly, they'd have grounds to sue you for deformation.
Im also wondering why you are so passionate in your denegration of Magic Cats product. Whats in it for you? Are you trying to be a good samaritan?
If Magic Cats product is not what they claim it to be, then i will take it up with them when i get my car on the road and emissions tested.
For now, Michael, i say Fu*k off until you have concrete evidence. You started this thread; i think you should finnish it.
Shaun.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
