  • Replies 162
Yeah guys, i wouldnt worry until we get some definative results. If the Magic cat fails, ill take it back and get a refund! It shouldnt be up to us to test it; but it'll be interesting. Thats IF it fails. im with shif_tea above^^^^.
Should it not be as simple as the company distibuting "Magic Cat" providing documentation to prove that their Cat Converters meet ASE or ADR ( or whatever they are ) requirements / regs ???? It just seems far too simple for the distributors to clear their name and get back on with selling their product........ :confused:
I guess on the other hand.......is there any documentation available for the "Catco" Cats that says "it" is approved for use in Australia under ADR's etc ??
I know the US / California regs are more strict than ours, but that does not mean by default that the parts are accepted for use in AUS.
I guess another question would be: Is ASE Engineering Approval required for the fitment of one of these cats since neither is OEM fitment.
Not trying to stir up any $hit. Just throwing a few more bones out there for all to chew on :(
Quick update;
I have a new Magic cat for the test
Thanks to BATMBL, I now have the measurements of the Catco (flange to flange is 317mm)
So I can now get the Magic cat's flanges welded on to those dimensions
That will make a swap over easy, if it is necessary
Thanks to ABFLUG we have a RAWS standard facility to test the emissions
I will post up more progress as it happens:cheers:
Quick update;
whilst you are at it should you want to compare to a genuine GTR car I have one sitting around. would be a good basline.
1. What diameter are the flanges/exhaust on the test car out of interest?
2. Still planning a dyno test?
3. My plans have been a delayed a little, so if you need another Magic cat for testing I have one sitting on my floor :(
Lucien.
Hi LW
1. 3.25"
2. I know the magic cat doesn't loose any power over a 3" piece of pipe on a car with 300 rwkw, already tested that several months ago. If we have time when tuning the Stagea I might do a back to back comparing the compliance cat with the Magic Cat. But I already know the compliance cat is crap, so it won't tell me much.
3. Might take you up on that, have you had the flanges welded on yet? If so what's the flange to flange measurement? (Hopefully ~317mm).
It has been my experience that genuine GTR cats are very good. What is the flange to flange measurement? (Hopefully ~317mm). If it is, then I might take you up on it as well, that way I can do a 3 way back to back. If BATMBL wants to loan me a Catco, I will make it a 4 way, emissions and dyno test. As long as ABFLUG doesn't mind doing 4 emissions tests.
PS; Julian/Ben/Martin if we do this, and I write an article, will you publish it?
No flanges welded on:  its still in its (dodgey) box and bubble wrap from Magic.  My interest -- hence the question -- in the dyno test is more to see if the Catco also has no negative impacts on performance.
Cheers,
Lucien.
This is growing all the time. If I borrow your Magic Cat, it will come back with stainless steel 3.25" flanges welded on it. Is that OK with you? Let's take this off line via PM if you like.:(
I'm excited!! this is the showdown of the century, beats all that shapelle corby sh1t for intrigue and suspense by far!! they should make a drama miniseries about this i reckon!!
EDIT: SK if those girls in your pics are in your crew, can i be too?? I'll do whatever you want, fetch drinks, clean the floor, polish your engine bay (thats not some sort of sexual metaphor either, it was literal). I'm beginning to think that i'm definitely in the wrong field!!!
I can see it now:
"Its a story, about a man and his Catalytic converter. Stuggling against the odds to clear his name, and finally be re-united with his exhaust"
Rivetting stuff, reckon we could get Russell Crowe to play the lead?? And someone like Al pacino to play BATMBL's part. hahaha
Ready when you are SK just let me know.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
