Hmmm totally stock hey... doesnt sound right.... Still stock exhuast & no Pod filter?  Care to post up dyno sheet?
Yep stock exhaust and airbox the its only had suspention mods so far. Even I was a bit hmmmm about it, I was expecting it to be alot lower. Have to wait till I get home to post up the sheet but.
https://www.sau.com.au/forums/topic/76308-dyno-figures/#findComment-1399194
flywheel - 30% RWD
flywheel - 40% AWD
Oooooh, here's a go :matrix:
So if I have GTR that has a standard engine and makes 250 kw, that means 150 4wkw. ie; the drivetrain and the dyno loses are 100 kw.
I take the engine out and swap it for an engine making 750 kw, that means 450 4wkw ie; the drivetrain and the dyno losses are 300 kw.
First question, how can the same gearbox, diff, tailshafts, drive shafts, wheel bearings, dyno rollers etc suddenly soak up another 200 kw?
Second question, according to Newton's law, energy can neither be gained nor lost, it is simply converted into other forms of energy. So where does the extra 200 kw go? Heat? That would be enough to melt the gearbox case on the dyno.
:cheers:
PS; Don't give me the E=MC2 argument, there are no atomic reactions going on in my Skyline.
https://www.sau.com.au/forums/topic/76308-dyno-figures/#findComment-1399649
First question, how can the same gearbox, diff, tailshafts, drive shafts, wheel bearings, dyno rollers etc suddenly soak up another 210 kw?
Second question, according to Newton's law, energy can neither be gained nor lost, it is simply converted into other forms of energy.  So where does the extra 210 kw go?  Heat?  That would be enough to melt the gearbox case on the dyno.
:cheers:
:Owned:
https://www.sau.com.au/forums/topic/76308-dyno-figures/#findComment-1399675
  • 1 month later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
