PRICE DROP 24,000 NEGOTIABLE
R33 GTSt M Spec
108,200km approx (bought in april 2003 with 88,000kms)
Mods (and i'll probably leave a few things out as theres so many)
APEXi PowerFC management with handheld controller
Turbosmart E-Boost electronic boost controller
PIVOT super baby turbo timer - stealth setup in ashtray
Aftermarket hybrid turbo (model is unknown but is larger and a lot better than standard turbo, boost comes on hard early and has a great meaty power curve all through the rev range) with reinforced wastegate actuator by Unique Autosports to hold boost and bring it on better
223rwkw
GTR front mount intercooler
Z32 air flow meter for more agressive tuning
SPLITFIRE 80mm boost gauge on drivers side A-Pillar
HKS exhaust cam gear
TRUST/Greddy oil catch can
New 6 button clutch fitted two weeks ago
GTR fuel pump and 550cc injectors (claimed when i bought the car from previous owner- have never pulled them out to check but i feel thats right as the fuel system would have maxed out with the standard items
3 inch exhaust off the turbo to high flow CATCO 3 inch catalitic converter into HKS Super Drager cat back exhaust system
Pod air filter enclosed in custom made insulated cold air box with induction piping from front bumper
bendix ultimate brake pads all round
Autowatch 3 point immobilser with digital siren alarm system
Sony Xplod Cd player
altec amp with 10" sub in box (for wank factor) pretty much unused in the garage
Carbon fibre gear knob
custom R33 leather handbrake and gearstick boots by Jay (SAU)
fire extinguisher set up in back
wheels are Speedy Holotype R rims 17inch
tyres about 6 months old 235,45,17's Hankook Ventus Sports
electric windows
airbag steering wheel (not available on series 1's)
REDLINE lightweight shockproof gearbox oil
always run with PENZOIL Turbo oil 10w-30
Genuine Nissan floor mats
100,000 Major service with new timing belt replaced at appox 93,000kms
rego till february next year (license plate ECR33M model ECR 33 M Spec)
1995 model, built 1994 (its a series 1.5) best bits of series 1 with series 2 engine and bodykit and a few other bits and pieces from the series 2
as you can see there has been thousands spent on this car and has been regularly serviced and lovingly taken care of
extermely quality interior (minus the few marks on steering wheel) (bloody japanese men picking at them)
25Kono
  • Replies 49
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
