Been having an annoying problem with the Stagea (RB25DET Neo) in that the Engine Warning Light comes on intermittently usually accompanied by engine retardation.
The dealer's mechanic have been tyring to fix the problem for weeks now. It started after they replaced the coil packs and fixed a rough idling issue. Now I get the above warning light although car runs fine when the light isn't on. Stopping and restarting usually gets rid of the light and can proceed driving.
The last attempt at fixing it was to replace the Cam Sensor (is this the Crank Angle Sensor? - excuse my ignorance) and change the timing. Worked fine for a few days but it is now back and it is becoming very annoying.
Took it to another workshop who advised it was Error Code 21 and said it was a strange problem and to try the Crank Angle Sensor as a first step.
Searched the forums and found 1 post where it turned out to be loose wires.
Hoping someone has some ideas of where to look next to solve the problem as not enjoying the drive at the moment. Plus thoughts on whether it is safe to drive (both mechanics have said it is).
Any help would be appreciated.
Cheers, Al
https://www.sau.com.au/forums/topic/76723-ignition-error-code-21/
  • 3 years later...
sorry to dig up an old topic, but it didnt have any responses and i am having the same issue with my series 2. have also searched the forum and most
other responses appear to be coil packs, however Alan mentions above that doing so didn't seem to fix things 100%.
Basically i've been driving the car since thursday night, and have had the engine light with the rough ride happen twice, and its fixed by simply turning the car off and
then turning her back on. i drove the car quite a bit over the whole weekend and it didnt happen at all, until thismorning.
we had a very similar issue with our one, turn off then on and the fault cleared. it came up as a CAS fault on consult. the CAS was checked and in good working order. the coils packs were replaced and the error went away.
buying new coils is an expensive way to trouble shoot but they are a common fault with neo's it seems.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
