Hi guys, just a simple question. I am from Melbourne and i want to get this car which is located in Sydney. Is it possible to register the car with VicRoads here then i bring the license plate up to Sydney and drive the car down myself? Instead of spending $300+ on transport fees. Anybody with good advices?
Cheers :crazy:
https://www.sau.com.au/forums/topic/76837-imported-car-in-sydney/
hey champ i had the same problem, im from sydne and bought a car from melb, i discussed it with the owner and we came to a easy sollution, he lends you his plates till you get to melb and do all the transfering when you get back to your place, then send the plates back to him in sydney, easy, we put it on paper and had it signed my myself and him and a few witnesses, simplest and easiest way.
What's the go with the car though??? You have imported it to Sydney??? Buying from someone in Sydney????
If it needs to be re-registered it would have to be inspected, or also if it has just been complied. If it hasn't had compliance, you would have to get it onto the back of a truck & then bought for Melbourne. Just give a bit more info & I (or someone else) would be able to help out more.
But when you register any car, you need the engine & chassis numbers, the rest of the paperwork will depend on it's situation (just imported/dealer car etc).
Nathan, thanx for the advice. The situation is that the importer is in Sydney. He just imported the car in for me and right now it is in a compliance garage. i know in melbourne, we need a RWC then we can register for the car. I don't think the importer has extra license plate though. Even if he has the plate, how am i going to get the rego sticker?
After compliance, the workshop will send all the necessary paperwork to dotars, and once they clear it they will send the compliance plate (that's now actually a sticker). Then it can go to be inspected, and once that's passed then it can be registered.
It really just depends on who is going to comply it, you won't be able to drive it from Sydney to Melbourne legally, so if the work is done in Sydney it would be better to go through the pits there & register it, and then drive the car home, but you would have NSW plates. If I was you I would just see how much it would cost to get it brought to Melbourne & get it all done there.
Good luck with it all though.
You can get day permits from RTA which allow you to drive from one destination to another only. But it aint worth you driving down from sydney to melbourne.
Reasons;
1. You will definetly add a few scratches to your car. Not to mention maybe even a few large dents. Those truckies on the roads drive like theyre in formula 1 cars, they keep spitting stones / rocks onto your car
2. You risk damaging vehicle
3. Drive for 9hrs//? Did it once, never again
4. Add to this, your fuel cost will be atleast $80
TNT transfer cars down syd to melb depot to depot from $330.
You forgot another point allblitz
If you have just imported a car, the mechanical history of which you cant be certain, then the last thing you want to do is drive it interstate unless you have it thoroughly checked and serviced in Sydney prior to making the trip.
lol ALLBLITZ, i agree with you mate..But TNT is $330 and yeah i understand the trucks issue. I drove up and back down to melbourne last year. It was crazy..trucks going at 120 or 130km/h...
Nick, my relative is a car mechanic in Sydney..he will service and check it thoroughly for me..and i am sure the car that i am getting is in a good condition. ( ALLBLITZ =P ) :jump:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
