is this right i thought it b a little more like 160rwkw
Mods
Gts-t R33 skyline rb25det
Computer - Link
Pod
Exhaust 3" think its a turbo back i will have to check with this dyno results might just b cat bak
Front Mouth Intercooler
Turbosmart type 2 BOV
Stock Boost of 7psi
what does a stock Gts-t Get
I know my boost is holding me back i want lower power to get used to the car
Putting a New Pod and Taking AFM out cause link doesn't use it
Might get a little Power gain from that
https://www.sau.com.au/forums/topic/76873-140rwkw-on-stock-boost/
For standard boost that sounds about right, with additional boost and the link properly tuned, you should see quite an impressive gain given that a GTS-T with similar mods using a Power FC can achieve between 180 and 200rwkw using the Power FC and standard turbo
dyno figures change between different dyno's. my car got 140rwkw bone stock and with a full exhaust, k+n panel filter and 9psi went up to 170rwkw. i use it more as a baseline to see what extra power the mods have given me. i am sure if i went to a different dyno the figures would drop a little
nah i know that rb25 r 185kw at fly stock i thought that b about 140rwkw with my mods i thought i get like 160rwkw :) o well i just up the boost later
Normally a stock R33 GTS-T would be in the region of 120kw at the wheels in true stock form
thanks man i just got the link tuned for stock boost they said the lack of boost is due to the computer being made for higher then stock Boost
ahahaha, i think you need to go to a better tuner as blitz said, as no ecu is made for higher boost, ecu are made to be tune at any level of boost,
also it isnt very hard to stop pinging and missing at lower boost with stocky mods, im running exhuast,airfilter,fmic,ebc and running 12psi with stock ecu and getting no pinging or missing
um dude, i think something is wrong with your engine.... have u done compression test on it? coz my R33 RB25DET did 163.8 rwkw with just a pod filter (everything else stock)..... then by putting splitfire triple plat plug and SAFCII (untuned) i got it up to 170rwkw..... then with a 3.25" catback exhaust (and jst replaced the cat with a straight thru pipe) i've got it up to 180.9rwkw..... on the 163.8 rwkw run, boost was 7.1psi <4500rpm, then >4500rpm it went up to 8.6psi... and from the latest run i think peak boost was at 9.1psi. I haven't physicaly done anything to alter the boost. According to my mechanic, larger exhaust pipe = faster flow of exhaust gas = more turbine speed = more boost :(. With FMIC and some kind of aftermarket ECU i'll be expecting somewhere around 200+rwkw....... on a stock turbo that is..... i'll post the dyno graph when i can find it... :confused:
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
