  • Replies 345
I may have listed these before.
Tough rims!!
WORK MEISTER S1
17x8 +25 all round
114.3 4 hole
Dunlop Lemans rubber.
Excellent condition.
Closing June 16th
Hi, issit possible to get the similar rims and size for a gtr ? 18inch tyres are a killer for me. thanks
Charles, whats the tire specs on these bronze TE37's? and condition? and ball park figure to Melbourne to my door? Also will 10.5's fit on a GTR32? anyone know?
VOLK RACING TE37 suit GT-R
18x10.5 +15
closing June 21st
these are fitted with Yoko Advan Neova 265/35/18 all round
less than 1000k's of travel total.
9mm of tread left. these things are like new.
this is the ONLY imperfection on the complete set.
this set was fitted on a 33 GTR. I dont see why they wouldnt fit on your R32 GTR.
Check PM for price to your door.
Cheers
Charles
The only rim similar in design available at this stage is a set of Oz Racing 3 piece rims.
disregard the label on the hub. they don't suit Ferrari.  lol.
New set. Ex display stock.
17x9 +24 offset.
$2540 landed
I own a set of these wheels, except w/ silver centres not gold. some C#$T stole my centre caps. You wouldn't be able to get your hands on a set would you?
-Patrick
Super Advan Racing
suitable for GT-R
18x9.5 +22
bids close 18/6
hi mate,
I have these rims atm. I am missing one of the little centre 'medallions' ie. I have the big nut bit, just not the little medallion and it's circlip. Would you be able to source one for me? I would imagine there are heaps around as they are a pretty popular rim in japan.
Thanks,
Richard
Beer Baron,
they are a popular wheel as you know however, it will be hard to find a seller willing to separate the medaion fron the rest of his cap.
I have spotted a seller selling just caps. At the very worst, we may have to bring in a full set of caps. As i mentioned to ocean, once i locate some, i'll PM you with what's available.
this may take just a bit of time.
cheers :P
Danny,
no full sets to suit your car at the moment.
here is what i have found anyways..
a pair of 18x9.5 +12 with good rubber. bids close tomorrow on these.
i can organise an additional new pair with or without rubber to complete the set.
this will work out a little cheaper than purchasing a complete new full set.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
