  • Replies 345
I may have listed these before.
Tough rims!!
WORK MEISTER S1
17x8 +25 all round
114.3 4 hole
Dunlop Lemans rubber.
Excellent condition.
Closing June 16th
Hi, issit possible to get the similar rims and size for a gtr ? 18inch tyres are a killer for me. thanks
Charles, whats the tire specs on these bronze TE37's? and condition? and ball park figure to Melbourne to my door? Also will 10.5's fit on a GTR32? anyone know?
VOLK RACING TE37 suit GT-R
18x10.5 +15
closing June 21st
these are fitted with Yoko Advan Neova 265/35/18 all round
less than 1000k's of travel total.
9mm of tread left. these things are like new.
this is the ONLY imperfection on the complete set.
this set was fitted on a 33 GTR. I dont see why they wouldnt fit on your R32 GTR.
Check PM for price to your door.
Cheers
Charles
The only rim similar in design available at this stage is a set of Oz Racing 3 piece rims.
disregard the label on the hub. they don't suit Ferrari.  lol.
New set. Ex display stock.
17x9 +24 offset.
$2540 landed
I own a set of these wheels, except w/ silver centres not gold. some C#$T stole my centre caps. You wouldn't be able to get your hands on a set would you?
-Patrick
Super Advan Racing
suitable for GT-R
18x9.5 +22
bids close 18/6
hi mate,
I have these rims atm. I am missing one of the little centre 'medallions' ie. I have the big nut bit, just not the little medallion and it's circlip. Would you be able to source one for me? I would imagine there are heaps around as they are a pretty popular rim in japan.
Thanks,
Richard
Beer Baron,
they are a popular wheel as you know however, it will be hard to find a seller willing to separate the medaion fron the rest of his cap.
I have spotted a seller selling just caps. At the very worst, we may have to bring in a full set of caps. As i mentioned to ocean, once i locate some, i'll PM you with what's available.
this may take just a bit of time.
cheers :P
Danny,
no full sets to suit your car at the moment.
here is what i have found anyways..
a pair of 18x9.5 +12 with good rubber. bids close tomorrow on these.
i can organise an additional new pair with or without rubber to complete the set.
this will work out a little cheaper than purchasing a complete new full set.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
