  • Replies 44
Got mine thanks.
Bit concerned with the health warning on the tube that says 'can cause unreversable effects"!!!
INASNT, the warning on the tube is real and should be followed. This stuff is toxic !! Use rubber gloves when applying or even better, trim 2/3 of the bristles off a paint brush and dab / brush it onto the part.
I say this as someone who's built aircraft engines for 12 years and has read the MSDS ( Material Safety Data Sheet ) on this product.
  • 5 weeks later...
sorry for the delay i have been out of country for a while and some one else has been looking after you guys give me a pm if you still havent got one and i will get right on to it im back in country on the 16th
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
