Sorry to dig up an old thread but it's all relevant :( I'm after the same set of plugs, but I can't seem to find any. I tried Coventry's on someone else's advice but they don't have any. I also tried ringing a couple of Mazda wreckers but they had none either.
Does anyone know where I can get them from in Sydney and roughly how much I should be paying? I'll try a few more wreckers in the meantime.
Edit: I'm going to try Findapart.com.au and see what happens.
Around $80 each is around average I guess. $100 isn't too bad. $50 is the "buy it now" price.
Update on my situation: I found a Commodore wrecker that has some plugs (for $5 each) but I didn't have time to get around there today. Maybe next week.
So they're not the same as Commodore plugs? Where do you get the "2 female pins" from? When I had a look a few days ago it seemed the pins on my clip are already approximately the right size and shape, just the clip was stopping them going on. So if I just remove the old clip and push the pins in, then silicon it up, that should work?
I did mine with pins I bought from Mitre10. I am not sure if the plugs are the same as Commondore ones. Use another set of wires approximately 3" long. Connect it to the new female pins. Test the resistance between the new terminals. If ok, squeeze silicon inside the injector socket and wait for it to dry completely. Connect the 3" long wire to the standard injector loom. You can choose to remove the old injectors plug or hide it somewhere. Preferrably water prove it in a tiny plastic bag. It is important to test the connectivity or it will be too messy to clear those silicon out of the way! Good luck
Originally posted by Clint32
Unfortunately there are a few different plugs, series 4 injectors are the same as GTR and rb20 ones, the series 5 ones are different, ive been told they may be the same as rb25 ones but i cant be sure they look similar on the fuel rail, anyone have any pics of some or some for sale.
Unfortunately the places im sure will have some are on holidays till the 6th so i may have to wait unless i can find some.
I doubt they are the same as RB25. I have seen those rx7 series 5 injectors. High impedance and top feed. If SR20 uses the same plugs as RB25 then they are not the same. The plug shape is slightly the same as the SARD 550cc injectors (oval). The 2 side grooves for the plug to slide in is slightly off tho.
Damn, I got off work early today and I forgot to go to the Commodore wrecker to see if they fit. I'll try to remember to go this weekend. My injectors look virtually the same as sil21jun's (but from that angle it's hard to tell if they're exactly the same).
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
