Hey, I'm looking at purchasing a non-turbo Skyline and was -up until a few minutes ago- set on an N/A R33 but I just found an R32 GTS25 (pretty rare I believe) for sale on the net and thought I'd have a look at some numbers and compare the 2 cars.
R33 GTS25 Type S
RB25DE
200 ps (147.10 kw) / 6400 rpm
23.5 kg*m (230.46 N*m) / 4800 rpm
Curb vehicle weight: 1320kg
R32 GTS25 Types
RB25DE
180 ps (132.39 kw) / 6000 rpm
23.0 kg*m (225.55 N*m) / 5200 rpm
I was surprised to see that both cars (in Type S form at least) weigh the same (1320kg). If that's true why does everyone make R33's out to be so much heavier??
Also what is the reason for the power/torque differences between the RB25DE in the R32 and in the R33?
All these figures were taken from http://english.auto.vl.ru/catalog/nissan/skyline/
R32 - http://english.auto.vl.ru/catalog/21746/
R33 - http://english.auto.vl.ru/catalog/21713/
I like the look of both cars, slightly preferring the R32 maybe, but the R33 has a bit more legroom for me (I'm tall).
Thanks. :confused:
https://www.sau.com.au/forums/topic/77372-r33-gts25-vs-r32-gts25/
Hey dude, long time no talk.
Regardless of those figures the r32 will definatly be lighter thats for sure.
Id say the power figures would be true as Nissan would of further enginereed the rb25 for the r33 as well.
R33s are heavier yes, but your only talking 100-150kgs really, which isnt heaps.
Alot of people make them out to seem alot heavier due to them being slightly bigger than the 32 but on paper the figures dont show a huge weight difference.
If you can find an r32 rb25de go for it i reckon, pretty rare and obviously you can slot an rb25det straight in there once you gather up the cash!! Thats the best of both worlds :D
Well hope that helped dude... after owning a 180sx both of these cars are roomy which i like but the 33 is slightly larger inside and out.
Jaz ;)
Overal the R33 is larger, and the extra power is most likely due to the rb25de in the r33 coming with the updated vct head.
I think when your considering an NA skyline it really comes down to visual preferance as neither of the cars are overly quick in the scheme of things, so basicly in the end all i can sugest ids go for what suits you best.
I like my R32 GTS25, was a great first car, and why i havent been able to let it go just yet, but eventually you start looking for more grunt.
Note that the non-type S R33 GTS25's are 190PS (139.75kw). Difference between the R33 models is that the type S has a variable capacity muffler. which the non-type S doesn't have, I think that explains the difference.
As for the R32 <> R33 GTS25 type S difference, as someone has said AFAIK the R33 has the VCT head, which the R32 doesn't have. The R32 also doesn't have the variable capacity muffler.
The whole weight thing is a bit of an urban legend, the reality is that the R33 whale actually weighs sod all more than the R32. Just the design makes it look a lot heavier.
Ultimately it comes down to your preference for the exterior/interior design, and the fact that the R33's are newer.
The R32 also runs a slightly shorter diff.
A friend had his TypeM R33 T on a weigh bridge. From memory it was slightly over the 1400kg mark without driver and half a tank of fuel. I can't remember the exact figure.
There's many weight figures floating around.
I remember seeing the R32 GTST TypeM 92 model weigh 1320kg.
The non turbo cheapo's were 1280kg's.
The earlier 89 models weighed a little less and the R33 GTST TypeM weighed 1380kg.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
