Hi guys,
Im tossing up weather Im gonna get a Lexus soarer or R33 Skyline at the moment, just wondering if you could list some common problems with the R33 GTST Skyline 1995 model in particular to look out for .. when buying a second hand skyline and just in general user/driver problems
cheers mike
https://www.sau.com.au/forums/topic/77464-r33-gtst-problems/
you're comparing apples and oranges.
if you're after a luxury hi-way cruiser, then go the soarer. a heavy car like it is well suspended for a good cruise feel. a skyline in other hand, is more a handling car. you can always put a firm aftermarket suspension in soarer to make it handle even better than r33 gts-t, but that kinds of spoil the true purpose of soarers.
i think both cars should be reliable piece of machinery when they're regularly had oil change & service. bad maintenance and wrong tuning especially when they're boosted up would surely gives u lots of problem, no matter skyline or soarer, rb or jz engine..
I have an R33, my brother has a Soarer so listen to me okay :(
The Soarer pulls harder in a straight line in stock form, however it is an auto so when it comes to going for a joyride, the manual R33 is a lot more fun. A lot! Both cars seems to struggle once the revs get up if you haven't done the exhaust.
The soarer in my opinion is nicer on the inside (my brother has the full black interior, sweet stuff) and the R33 in my opinion is nicer on the outside.
Both cars are reliable when purchased in good condition. Both of ours are 94 models, however my turbo crapped itself and his gearbox crapped itself so both of them have been upgraded.
Stock for stock? I'd take the Skyline because a slightly lighter, manual is more fun to drive, even though is loses out slightly in a straight line.
My car vs his car? Weeeelll I have $10k of mods so there's no comparison. None at all.
:sadam:
cheers mike
Iv'e had my 98 R33 GTST for 12 mths now , Had no problems done 98,000 Ks. Like new inside & out ,no mods to the car .just like new .
Mike, I have both in the driveway, that is if you are looking at the V8. As Rianto said, apples and oranges. Don't even think of the sixes in the Soarer. Lowbrow low budget wannabes. V8, leather with as many options as possible including the airbag or active suspension.
Yeah, there are problems with both. Take a look at the ALSC website for Soarer problems and fixes. http://www.lexus.australia.as/entry.htm
That's a tough call mate, the IJZ it widely considered to be one of the best inline 6 cylinder engines in the world... I wouldn't consider any of the Soarers to be "above" another, all are similarly priced and I see just as many V8s as 6s.
After having the 1jz in the Mark2 I can highly recommend it.
It would hand the V8 its arse in a race no problem. :rofl: However they do not come with the leather, no. I would fore-go this luxury to be able to move around faster then an v6 commodore....
Mate look over there :rofl:. Reach across and crank up the tunes on the 7 speaker sound system (91 model with over 200K km and it still sounds great) but hey, I do still like to build a crankin' stereo as in the Lynx I have so I have something to compare it to.
If you want to race, get a GTR or work hard building a GTS25t that will go for that rwd action. In fact I'm selling one of the five cars to keep the Soarer, and it's the auto skyline R33 that's going as I also wanna keep the 4 banger Lynx.
Once again though, they are different beasts and I couldn't choose between the GTR, GTS25t and the Soarer so I just keep them all.
You'll have to change that username then :rofl:
With the Supra, try stick with the later model (I recall after 95/96) for the better brake package. No idea of price lately and I expect they are holding value well, but an early GTR32 might be a better priced option.
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
