Right, so three of my sensors are faulty, which I am going to check today
Outside temp sensor
Sunlight load sensor
PBR
What the Fark is a PBR? anyone?
I have also found that the heater element wasn't the only reason my heater wasn't working - the diverter flap that sends air to the heater is also not working - hopefully it is related to the faulty sensors, and hopefully the faulty sensors are just disconnected or something!
I will keep you posted!
https://www.sau.com.au/forums/topic/77493-climate-control-diagnosis-pbr/
The sunlight load sensor may not be faulty. Even parking under a tree on a bright summer day can still produce a "faulty" sunlight load sensor. Shine a bright torch on it while in diagnostic mode to confirm if it's faulty.
The PBR has been covered previously - do a search (from a while ago, maybe 12 months or more).
The sunlight sensor is on the dash. Its tucked in all the way in the left corner.
The outside temp one is at the front, around the horn somwhere.
PBR - not sure.
I have some problems with the heater too. I cant change the temparature, it's stuck on hot.
Now when you mentioned it, it must be that diverter flap.
Where is it actually located? How hard is it to fix it?
The reason I asked about fuses is that if a fuse blows you can get erroneous sensor warnings. Double check all the fuses (there are three for the aircon IIRC), and if you have found one has blown obviously replace. My guess if it blows again is that you're suffering from the same problem I am: worn out windings on the aircon compressor magnetic clutch.
Cheers,
Lucien.
Success! Thanks blind elk, and to the R32 gtr manual i found on the forum... For some wierd (and bloody annoying) reason if you search for pbr, you wont get any results....
This thread - http://www.skylinesaustralia.com/fo...read.php?t=5589 - pretty much sums it up.
If PBR comes up, it means the the servo that actuates the heat/cool diverter door hasn't reached the desired opening. So my suspicions were correct, it was related.
You can see the servo quite easily by looking in towards the heater from the drivers side. Instead of pulling it apart, which i was planning to do as the guy in that thread had had success with, I pretty much accidentally got it working by just pushing on the lever one way and the other to see if it would move... and it did!!! hooray!!! I now have climate control! It must have just jammed up from lack of use, and all it needed was a bit of coaxing. i then adjusted the temp from high to low and lubricated all the moving parts till i was satisfied with it's operation. It might pay to remove the diverter flap actuator bar from the servo while playing with this, just to make things a bit easier. I ended up pulling the whole thing out and giving it a good hit with lube everywhere i could.
The Pbr fault comes up still, but as it turns out, to satisfy the self diagnosis, the flap has to be opened at 40%. so if you can still get hot and cold, dont stress about seeing the fault. another little thing to know, if you get a minus sign in front of any of your numbers ie -26 , that indicates a short, (or overload) which now that I know that, would also point to a stuck servo.
My sunlight sensor fault cleared as soon as i... well... put it in sunlight :)
So now my only problem is the ambient air temp sensor. Putting a multimeter across it, it works fine, but the fault still comes up. But i'm not that phased, as i dont think it has that big of a bearing on the climate control operation.
So now I'm one happy, warm, camper!
Just read that link Jolinator - bloody good find!
Bumpy, need some help.
On my r33 i go to diagnostics and i have a stable 2, and a flashing 5. I know this is the Light sensor on the dash. The thing is that even though i have my aircon on set on 18deg it blows really hot air. I also have a nissan Pathfinder, it also gives the same result, a stable 2 and a flashing 5. But the climate control works perfect on the pathfinder.
I thought i heard people saying that 20 was normal... im kind of confused...
Hmmm, now all of a sudden its only blowing cold air. Its like deciding by itself whether to use the aircon or heater...
Godzilla: Turn on your ignition, within the first 10seconds, hold the off button on your Climate control (for 5 seconds), and you will see it enter diagnostic mode.
has anyone had any luck? i thought mine was working, but my problem is such that it wont open unless i put it on FH then bring it back down, then after i turn the heater off hot air will continue to come out of the dash, unless i put it on FC then turn it off, so my problem is such that the arms dont return to the closed position after the AC has been turned off
pull the thing apart mate, that's what I did and the PBR "fingers" were partially fused to the board. you'll need to pull the circuit board right out to see the actual PBR. Sounds like you have the same problem as I did. I'm buying another actuator as we speak... It's a used one so i just hope it's not rooted too... will be pulling it apart and lubing it as soon as i get it!
Nah mate, inside the air diverter flap actuator, the one you can see if you look in under the dash toward the heater from the drivers side. looks like this - pull it right apart and you'll find the PBR on the underside of the circuit board. The PBR is a position sensor- Potentio ballast resistor - works like a volume knob in a fashion. it senses the position of the plastic arm you see in the pic, based on the resistance it sees, which varies between low and high depending on which end of the circuit the pickup is on. Sorry if I'm being patronisingly descriptive, just tryin to paint a picture for ya :D I didn't have a clue what it looked like until i saw it!
the box is mounted on a bracket and you'll see that it is connected to a metal bar running in under the heater system. The other end is attached to the air diverter flap.
When you pull it apart you'll need to pull that arm off - I broke the clip that holds it in, but I dont think it really matters (especially not now lol), undo two screws in the bottom and pry it apart carefully. pull the gears out, and the board inside has two screws from memory, undo them, and carefully pry it out. look at the underside and you'll see the PBR.
Hope that helps!!!
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
