regarding hanging all over the track, i dont want to be like in those clips i see on the net where a spectator wonders onto the track and gets clipped/dodged by the rally car b/c his/she was too close. hehehehe how embarassing would that be, telecasted to all to see how you got owned. !!!
http://www.rallyofsa.com.au/Forties1.html - has a map of the viewing areas, there's a spot in the middle between the two hairpins of the Forties and Ridgetops stages, is that it?
Anyways i hope everyone else found their way back to this thread since my old link wasn't working with this new forum migration.
Okay, based on the poll in the other thread we've settled on Saturday for the day, the meet point will be the regular place in the North East, but I'll send out PMs on Friday to all those who've posted in here thus far (if you've been lurking then make yourself known now so i can message you).
As for a time, the Rally action starts at 8:30AM, it'll take ~1hr to drive there (maybe more if we get stuck in traffic?) plus: parking, getting the shuttle bus, buying tickets, finding a good spot, etc.
So I say, the earlier the better, i know i originally threw around 9:00AM but unless people are particularly against:
8:00AM Meet, 8:15AM Depart.
Nozila, Sambo33, Deluxe, and Boof haven't been active since teh forum change, all my email notifications and old links stopped working so they may not know what's going on.
I have Sam & Duc 's mobile ph. no. 's so i can get in touch with them and pass on the details no worries, but it's the other two I'm worried about. I'll PM them all regardless but if anyone has alternative ways to contact them could you please pass on the info?
Cheers,
- Ash.
Okay this is my last message before i knock-off work and start drinking beer ;)
Remember to pack some warm clothes, BOM has tm as "Min 6 Max 16 Fine. Mostly sunny" for Adelaide, so hopefully it wont rain.
See you all at 8:00AM at the location i PM'd you.
It was a good day! Having never seen the SA rally before, I was keen to go have a look. It turned out to be a bit difficult for me because I didn’t have my car back, and living on the other side of town from the meet up point. Id like to thank Oosh for the accommodation & driving me around, also thanks to Nightcrawler for the hills-run in PCOTY & the 8-ball. I should have some rally pics up sometime in the next couple of days. ;)
Cheers,
Sam
It was a good day! Having never seen the SA rally before, I was keen to go have a look. It turned out to be a bit difficult for me because I didn’t have my car back, and living on the other side of town from the meet up point. Id like to thank Oosh for the accommodation & driving me around, also thanks to Nightcrawler for the hills-run in PCOTY & the 8-ball. I should have some rally pics up sometime in the next couple of days. :D
Cheers,
Sam
You're welcome mate, any time, and thanks too for the 8-Ball Andrew.
I had a good day, well worth it, and I should have some pictures up soonish...
Hi guys,
My rally plans were changed on Friday afternoon when the master cylinder on the clutch went at Southgate shopping centre. Lots of V8 drivers smiled/laughed as my beloved GTR was towed away. Anyway still made it to the rally in a mates car, saw Andrew's S15 in the car park and a few skylines but didn't see you guys at the track. Tried to call Ash but had no mobile coverage. Hung around to 4:30. Was freezing all day and got sunburnt... at least the fires were toasty. Great day topped off by going to the drifting yesterday where I saw heaps of skylines in the carpark (and two on the track).
Hi guys,
Bummer, shame we missed you, who are you with, as I had pretty reasonable coverage from Telstra GSM at the track?
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
