  • Replies 52
all the best jon, you and your baby will be missed, I am sure u will be rapt to get her back on the 7th. watch out for all those vic coppers, they arent known for their tolerance or friendliness... sure hope you like AFL, cos the victorians are one eyed about it!!!! (league gal myself)
Only ever met you once but i think you were the first person off the forums i talked to. All the same, have a good one mate!
I think you meant to say "he was the 1st person off the forums that WOULD to talk to me" :uh-huh: :Pimp2:
oh sorry my bad, i thought you were Lee. hahaha jokes Lee!
you say i am a bad speller... well its true i know but at least i can spell peoples names right and considering mine is under every single one of my posts you are up their with me now :uh-huh:
wtf cassi? I dont see how you say your gonna miss him, you said to my face the other day that he was single handedly the biggest asshole on the face of the planet, and there will never be a bigger asshole than him.....remember you even wrote it down for me..... then made duplicate copies...... so that if you ever changed your mind i would have to show you the copies to remind you just how much you hate him!
Jeez your so 2 faced, i thought better of you....
bahaha :crazy:
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
