Just bought a GTR this month and I'm about to do the 100k service on it this weekend.
I was wondering if anyone has the suggested service checklist for it? Want to know what should be done for this service and also the recomended oils and quantities as well.
I'll be doing it myself so I wanted to get a check list, to make sure I get everything.
Currently I'm planning on:
* Replace engine oil filter and oil
* Replace gearbox/transfer case oil
* Replace differential oils
* Replace fuel filter
* Replace air filters
* Replace spark plugs
* Replace timing belt, idler and tensioner
* Replace water pump
* Replace coolant
* Replace brake fluid
* Replace clutch fluid
* Inspect/lubricate steering components (wheel bearings, ball joints, tierods, boots, etc)
* Inspect/lubricate drive line (drive shafts, yokes, unis, boots, etc)
* Inspect suspension (shocks, bushes)
* Inspect all hoses
* Inspect/adjust accessory drive belts alt/ac/ps/wp/etc
* Inspect brake pads & rotors.
The other thing I was interested in, was the water pump. Same pump as RB30E VL Commodores or what? I was led to believe the N1 GTR's had a different pump, but apart from that the standard GTRs had the same pump as VLs. Is this correct?
Cheers. :);)
Robbo.
Thanks for all your help :)
Some may find the following prices interesting.
Gates racing timing belt.........$93
NTN Timing belt tensioner......$60
Powermax waterpump...........$65 (Same part # as VL according to supplier)
Nulon coolant conc. 5L..........$30
Mobile 1 engine oil................$50
Motul Gear oil (gearbox & difs)
4.9L+1.5L+1L = 7.5L............$100
K&N oil filter........................$20
Ryco fuel filter.....................$12
NGK platinum plugs...............$82
Nulon Oil flush.....................$8
Nulon coolant flush..............$5
Nulon Xtreme brakefluid........$12
Bosch w/p belt...................$19
Bosch a/c belt....................$14
Bosch p/s belt....................$20
Genuine thermostat..............$50 (looks different to VL but possibly interchangeable)
515 Gasket compound..........$10
Total $650 ish... All these prices were at trade or mates rates.
And I'll be installing/fitting it all this weekend. So wish me luck!
R32 GTR w/pump is not the same as RB30 w/pump (skyline or VL commode). Some will try to tell you otherwise, but I've got both types and compared them face-to-face....there's a single 6mm bolt at the top that's in a different location in each case. I've read here of people using the RB30 pump and just leaving the bolt out.....personally I wouldn't risk it.
The downside is that the genuine R32 GTR pump is $300+ and to answer you're next Q....R33/R34 GTR pumps don't fit R32 GTR as there are design differences which also mean these pumps will leak. However it is possible to modify an R33 w/pump to fit an R32, but requires some welding and machining. R33 GTR w/pump costs around $140 (trade) so if you know someone that is handy with a TIG welder and has a mill then you can save some $$$.....that is what I did.
Haven't done the brake/clutch fluid swaps yet. might think about that.
I've already bought the VL water pump, I may as well compare them both. If I'm comfortable with leaving the bolt out I'll go with it. If not, looks like I'll be going with an R33 GTR one, and modifiying it.
I ended up getting the Cam belt Idler as well. Then I found a slight weap from the inlet cam seal. So I'm going to get a set of genuine cam seals and a front crank seal too.
Consider just buying the OEM one. All of these aftermarket ones with their X or Y times greater strength are fine, but given you should be replacing the belt after the next 100,000KM I am not sure its worth it.
I assume those a different types of gear oil for the box and diffs? Also think about the transfer case.
Think about just running some coppers. Yes you have to change them more often, but for $2 per spark plug, who cares? ;)
I have never heard good things about flushing products. Your milage may vary. IMHO you are better off buying an extra 2L of engine oil, half drop the oil, top up and run it through, then drop the lot and refill.
As per above. Consider completely removing the radiator and having it professionally flushed. I posted up a tutorial for that awhile ago.
As others said, get something better. Motul DOT5.1 seems quite popular.
Lucien.
I used the same oil for Gearbox, and Diffs.  Is this going to be a problem?
Not a good idea AFAIC....ordinary gear oil for the gearbox, but diffs need a hypoid gear oil. If you've used ordinary gear oil in the diff change it to a hypoid GL5 type ASAP.....short term use probably won't do any damage. OTOH if you've used hypoid gear oil in the gearbox no damage will be done, but synchros may not work correctly - again, change ASAP.
Edit: I've realised you might mean the same brand of oil, not necessarily the same type.....if that's the case, my apologies :(
:werd:
Lucien.
I'll find out more about what I bought and try and rectify the problem. Luckily nothing has been refilled/changed yet.
Thanks for picking up on the problem. I'm sure it would run fine for the time being with whatever oil, but when I'm paying $100 for 7L... I want it exact.
Cheers, I'll keep you posted.
The other thing to remember is that the rear diff on a GTR is a mechanical LSD and you need to use a hypoid gear oil suitable for LSD diffs. OTOH the front diff does not have an LSD centre so an ordinary hypoid gear oil can be used in that. Of course I'm assuming your car has the factory setup, but it's fairly rare to find an LSD fitted to the front diff of a GTR. If your not sure, it's perfectly safe to use an LSD spec diff oil in an open centre diff so just do that (plus it simplifies the types of oil you end up buying......)
SteveL:  The rear diff doesn't require oil with any special friction additives.  Any of the standard hypoid GL5 diff oils is fine (rather than those LSD specific oils) IIRC.
I tend to use oils spec'd for mechanical LSD's. I suppose those are special additives but I don't look at them in the same way as stuff like Nulon, which are just unnecessary and a waste of $$ IMHO.
If you look at some of the differential oils -- like Castrol SAF-XA -- they say they are fine for LSD applications: obviously if the oil manufacturer doesn't recommend its use in an LSD, don't use it :cheers:.
What I am saying is you don't need to get the ones with friction modifiers.
Lucien.
Lucien i regard myself as i fairly confident person in the way of mechanics. Im 24 now and im assuming your 23 as thats wat it says on your details but damn mate you know your shit! Smart guy, thats for sure. How did you have this much experience and still be so young? Ive been working on cars since a very young age. Got my first car at 14, but you have more knowledge on alot stuff than me!
Anyway before your head grows too big and you cant get thru doorways no more i'll stop!
While im here how do you knwo if you need to replace the ancillary blets ..Mine arent too bad looking but they are all off so i was thinking to swap em over. One looks a tad worse than the other 2 ...how should i decide?
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
