Alan, thats a difficult question when we know nothing about your car or its modifications. These intercoolers are a bar and plate design 600 x 300 x 76mm
  • Replies 40
hey
 nice price... i want to buy a kit for my r33 series 1
No problem, please email [email protected] or call us on (02) 9545 0532 to place your order.
Thanks
Steve
Anyone that can help....
Just deciding between Type 1 and Type 2.. I dont care at all about the looks, just after the performance and installation ease.. I have a r33 series 2 front bar, will they both fit in snug? with out too much cutting. Also, it looks like the type 2 has bigger end tanks, does this equal a better performing intercooler?
Cheers...
Hi,
I was considering buying one of these kits however I've noticed that on my R33 (S2 Sedan) I've got a washer bottle located where you would normally cut the 3"hole (on the drivers side). So the question is, will this kit fit?
Hi Bunky - We havent fitted one of these kits to a 31 so I cant give you a definate answer.
We have an SAU forum special for the coolers themselves at $175 delivered otherwise.
Steve
thats awesome... how long will this be going for? ie. my car probably wont get here for 2 months.
and will u have the blue piping for the R32 kit??
Hi Steve
Q1 Do these kits bolt straigt up or do you need extra brackets and holes?
Q2 Has anyone got a pick of one of these fitted before the front spoiler is fitted back on.
Can you PM me the details of total cost for Type 2 R33 Kit
delivered to Bunbury WA.
Instructions on how to pay would be good thanks
  • 1 month later...
More stock just arrived.
Note: The Type 1 kits now include chrome piping rather than blue piping.
Regards,
Steve
Plenty of stock available, first post has been updated.
Cheers,
Steve
Hi,
Has this question been answered yet? Some pics or copy of fitting instructions would be great, if possible.
Peter
Hi Peter, the cooler pipe runs through the inner guard underneath the washer bottle.
A 3 inch hole will need to be cut to accomodate this in the inner gaurd under where the washer bottle is sitting.
The image below shows what I am referring to, though in an R34 the battery sits where the washer bottle would in an R33.
Please let me know if you have any further questions
Cheers,
Steve
Hey Steve, the type 1 and type 2 kits one looks like it has larger end tanks? Any reason why? Whats better?
Also the ones you have for $175 are they the smaller end tanks or larger ones?
Hi Doodz, the type 2 are simply a trust style intercooler with a slightly different shaped end tank and polished piping whereas he type 1 kits use the same cooler as the $175 universal units and chrome plated piping.
I hope this clarifies.
Cheers,
Steve
Is there any chance of getting the type 2 cool just by itself?
This shouldnt be a problem. Give us a call to discuss - (02) 9545 0532
Cheers,
Steve
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
