Only have 2 of them - really like them but doesnt really write on the back what they are.
All it writes on the front is A-tech Monoblock or something. Searched around but couldnt find out.
Hopefully someone here will know.
Ohh yeah, talking about the wheels on the front : )
Thanks.
Husnu (Hus).
https://www.sau.com.au/forums/topic/78031-what-wheels-are-these/
They look the same as the ones I've got on my 32. If they are, they are A-Tech Monoblock Forged Alloys that have a sticker on them saying "Final Speed"
I know more about the wheels if you need to / want to know.
What's the go ? Do you just want to know what they are or are you looking to sell them or .....??
I think we might be getting somewhere. I only have the front pair. I need to find another 2 to make it a set. The ones I have are 17x9JJ
If I can find atleast 9JJ for the rears it would be good. If not, i might have to settle for 8-8.5JJ and shift the 9JJ to the rear.
I like the wheels, no good having only 2 of them. If you know where I can get them it would be great. In the mean time, i'll try and hunt them down in Japan.
Thanks a lot.
Hus.
I'd say those ones are the next generation of the ones I have as they state "Semi Solid Forged" where as mine say "Monoblock Forged Alloy" and mine do not have the red word "forged" on the sticker but hey, they look the goods. :rofl:
Selling price here is Aus was ( don't see them being sold new in Aus anymore ) around $400 - $450 per wheel.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
