If it's a track requirement it has to be in reach of the driver when strapped in as far as I can guess.
I'm mounting mine to the raised floor part behind the glovebox (the tunnel that the driveshaft goes under).
I know of people who have mounted it in the passenger area (although I kept away from that to stop them from getting a fire extinguisher in their knee incase of an accident).
Also seen people use a plate to mount them to the seat rails and have it just behind them.
Don't get the crappy noname/cheapy ones from autobarn/repco/wherever. Mine leaked all over the place (both of them) and when I had a fire they were both useless. Garage-13 sell chubb ones pretty cheap.
I made a bracket up & bolted the extinguisher to the front of the drivers seat rail. Means you can't move the seat forward, but as I don't share the car with anyone - who cares. When you buy your extinguisher get one with a metal bracket (Mine is a Quell) & also have a look at the date stamped on the handle - go through the boxes & find the most recent.
Mines bolted on near the passengers left leg. The seat can still be adjusted all the way and it doesnt get in the way of the passenger getting in and out. And easy to fit there, no making or adjusting the brakcet that came with the extinguisher.
  • 3 months later...
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
