hello, i have a forward facing plenium for sale.. it suits a rb20det ecc. It made over 300 horses @ the wheels with no problems. Its completely polished and in great conditon. I have pictures emai [email protected]
its basically the standard maifold with the throttle body moved to the front of plenium.
280 ono
Cheers justin
*****PICS FURTHER DOWN THREAD*********
https://www.sau.com.au/forums/topic/78115-rb20-forward-facing-plenium/
  • 4 weeks later...
sorry guys.. finally got pictures.. had a heap of interested..first in best dressed..suit a ECC aswell
Cheers guys
Justin
0422944604 if you keen
Justin
Hey mate, Im very interested
SMS sent
  • 1 month later...
wer does the accelerator cable hold onto ?? if you look @ one of the photos above..there isvacume pipe which has fallen onto the accelerator holder cable thingy..if you take a close look you will understand me..otherwise give me a buzz on 0422944604 and ill explain it bettter
were there any vacum lines blocked or removed? no all used
let me kno!
where u at? im in perth..no problems sending over east
Cheers justin
Edited by hurtinit
  • 1 month later...
  • 4 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
