Im really curious to know what the noise is comming from the area around my front strut its kinda like a creaking noise ...
only when the car is cold in the mornings then once it warms up it disapears !!!!
beats the hell outa me what do you guys think it could be???
:confused:
https://www.sau.com.au/forums/topic/78176-what-the-heck-is-this-creakin-sound/
I think it has something to do with the colder weather ?
The shocks/bushes are cold and thus making creaking noises ?
Perhaps im wrong ?
Yep mine too, only started the past few freezing days. Steerings gone a little bit heavier too, or maybe just my imagination...
Had a slight creak in mine when I took off from stop. Apart from replacing a CV in the front (which I don't think was the cause), the guys tightened up all of my suspension and cross members - creaking noise is gone. Probably just contraction from the cold allowing a little more give than usual in the suspension.
seems strange but i have the exact same issue..
mornings it creaks but after like a 30 - 40 min drive it stops most of the time.
had the brushes replaced and this stopped it for a small amount of time.
but i think it is the shocks that have worn on mine.
replacing them soon anyways
my car squeaks when you change direction mainly... i.e. when you pop her in reverse it makes a little creaking noise and then back to forward gears. my suspension guru in canberra is part genius, and he reckons its just the bushes/mounts doing their thing and theres nothing to worry about.
and on that note, my bilstein/eibach suspension is slowly shaking my car to pieces. my boot rattles horribly (not stereo induced) and half my interior squeaks, rattles and carries on.
not looking forward to the day i actually pull it all to bits and fix it...
d
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
