Im really curious to know what the noise is comming from the area around my front strut its kinda like a creaking noise ...
only when the car is cold in the mornings then once it warms up it disapears !!!!
beats the hell outa me what do you guys think it could be???
:confused:
https://www.sau.com.au/forums/topic/78176-what-the-heck-is-this-creakin-sound/
I think it has something to do with the colder weather ?
The shocks/bushes are cold and thus making creaking noises ?
Perhaps im wrong ?
Yep mine too, only started the past few freezing days. Steerings gone a little bit heavier too, or maybe just my imagination...
Had a slight creak in mine when I took off from stop. Apart from replacing a CV in the front (which I don't think was the cause), the guys tightened up all of my suspension and cross members - creaking noise is gone. Probably just contraction from the cold allowing a little more give than usual in the suspension.
seems strange but i have the exact same issue..
mornings it creaks but after like a 30 - 40 min drive it stops most of the time.
had the brushes replaced and this stopped it for a small amount of time.
but i think it is the shocks that have worn on mine.
replacing them soon anyways
my car squeaks when you change direction mainly... i.e. when you pop her in reverse it makes a little creaking noise and then back to forward gears. my suspension guru in canberra is part genius, and he reckons its just the bushes/mounts doing their thing and theres nothing to worry about.
and on that note, my bilstein/eibach suspension is slowly shaking my car to pieces. my boot rattles horribly (not stereo induced) and half my interior squeaks, rattles and carries on.
not looking forward to the day i actually pull it all to bits and fix it...
d
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
