Hi ppls,
Bl4ck32 and I have an AP Engineering R32 RB20DET PowerFC.
We have ran in to issues (Bl4ck32 Specifically) where the load points are being maxed out preventing more boost and power.
We are both running RB30DET's, using the R32 RB25 head and RB30 bottom end.
I am making 176rwkw and Bl4ck32 is making 200rwkw.
I use load point 19 to make this powe rand Bl4ck32 uses load point 20.
The problem is the PowerFC appears to have ran out of load points. :rofl:
I have replaced my stock airflow meter with a Z32 item, it didn't change the load point used, only the voltage per load point.
i.e The Z32 AFM it now peaks at 4v (thats load point 19) vs the rb20 AFM at 4.9v (that was also at load point 19).
Bl4ck32 is using a Q45 AFM. Same thing, only voltage has changed not the load point used.
So.. The larger (not literally) AFM doesn't reduce the load point used, what can I and Bl4ck32 do now?
What load points are some of you ppls with PFC's using at WOT and what power are you making?
Any tuners out there care to shed any light on our brick wall?
Our Tuner is contacting Apexi to find out what he can do, he has used the Datalogit software previously and said it cannot change the load point scale.
I've attached a pic of the AFM Menu that is located within the Settings menu.
All of the AFM menu AFM items contain the same values.
I am thinking *hoping* this 'may' change the load points used if the 3.84-5.12v is changed from say 100% to 80%??
Similiar to the way a SAFC works.
https://www.sau.com.au/forums/topic/78309-powerfc-ran-out-of-load-points/
He said that it cannot change the load point scale, or that it needs some correction added to one of the tables.....me cant remember exaclty :rofl:
The tuner has no issues making 200+rwkw with other rb20's and their PFC's (Chris32) as higher load points at higher rpm = over 200rwkw.
However, I think it does come down to his lack of experience with the rb20 pfc. Generally speaking he does a good job tuning and tunes safe, not to mention he charges bugger all.
The only other tuning shop I would touch down this way want $600 (Tilbrooks).
Others have a reputation of breaking things and or simply not giving a good tune via the PFC.
It appears RB25 pfc's are calibrated differently as at wot and 200rwkw or so they are only hitting load point 15 max. So obviously a lot of head room.
Can ppls check out their Airflow menu? :rofl:
mine goes up to load point 16 or 17 on 9psi - RB30DET with 25 head in r33 with r33 pfc. Does this mean i will have this problem when i finally want to run bigger injectors for bigger boost ? they are running at 90% + atm and im only running stock injectors
interesting...
Mine gets up to load point 16/17, somtimes 18
I wired in the Z32 and selected the Z32 AFM option, otherwise it wouldn't run at all with normal AFM selected
Could it be becasue the AP PFC uses a GTR PFC, and being configured for only the one AFM its using more of the map than it would with 2 AFM's?
I remember in a old Zoom mag they where talking about the fc-logit software being able to extend the map in regards to RPM, but I dont remember it mentioning load
Maybe SK could shed more light, as he runs FC-logit and the RB20 PFC on his R32 RB30 setup doesn't he?
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
