Hi,
I received a defect notice that was a self-clearance. I have made the changes, signed the notice along with a certified db test (done at an exhaust shop with the correct testing gear) and handed it in at the police station. The lady at the front desk said she'd pass it on to the officer.
My question is for self clearances, should i be expecting an acknowledgement for the defect being cleared or is signing a self-clearance the end of the process?
https://www.sau.com.au/forums/topic/78358-self-clearance-defect-notices-qld/
i think that signing it is good enough but if you get pulled up again and those defects are still on your car they can fine you and take points. (dont quote me on this) best thing to do is ring up the D.O.T and ask what is involved with a self clearance notice and how does it work???
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
