hey jimih well i been told as im after the same info of my rb26 engine and people have said to compare to engine number to others that u know the year of and it goes in numerical order obviously.
my engine no. is: RB26 001 820A
any info or ideas on that ? :confused:
thanks
Brad
thanks
Brad
89 model very early
G'day mate
G'day mate :)
Yeah that would sound feasible .... anyone else ?
My engine number is RB26 031 534A
Anyone with GTR's wanna put their numbers up?
(of course assuming you believe it's still the original engine!)
92-93 model and topaz yours is the same 92-93
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
