Hey guys, i had my second run in with the boys in blue tonight got done for a few things :P
One thing that has me a bit stumped is i got done for having something done to the area where my back speakers are.
i bought the car like that, and the policeman goes you'll need a engineers cert for that.
I asked him what the problem was and apparently they had to make room for the speakers or something and that it could affect my car during a crash if i get hit from behind or something like that???
Anyway how much do those things roughly set one back? i looked at a few of the nsw threads about it but prices may vary here?
Any help apprciated!
https://www.sau.com.au/forums/topic/78431-engineer-certificate/
Engineers are $500, you'll probably need to replace your parcel shelf if it has sections missing, ie bits have been cut out to make room for the speakers.
My car came with the most poxy "custom built" parcel shelf made of two pieces of chip board sitting on each other. I've built a schmik replacement that's as tight as a nun's ****, could I get dicked for that? :confused:
engineers reports vary in price from each engineer/workshop to the type of modification/car... i dunno how you guys came up with these figures..
get a list of vicroads certified engineers and ring them all up to discuss your issue and the best price...
i called up about 6 engineers whose numbers i got from vicroads and the cheapest i found was $660
If you can find cheaper please point me in the right direction.
What does it exactly say on the canary notice and fine u got?
Does it say full roadworthy needed?
I would be checking exactly what they wrote you up for coz he might have said u need an engineers report for your parcel shelf but didnt write it officially down. Wouldnt want to go wasting your $$ on something you dont need. You should get the parcel shelf fixed properly but may not need to pay an engineer to look at it for 10 mins and charge you alot of $$. They charge so much for their signature because if you are in an accident and they investigate and find the item they signed off for was faulty they will get reamed, so they are just covering their asses.
I was told a bunch of crap when i got done years ago but all they wrote was I needed a full roadworth. When the roadworthy was done they didnt worry about any of the crap i was verbally told, and when you hand in the paperwork at vicroads they couldnt care less either.
i got done for:
Ground Clearance - my cars to low.. fair enough :)
Tyres (2) - they are 89v or something when they need to be 90v or above, load rating or something?
Tyres (1) - front drivers side had a bald strip along the inside of my tyre cause car needs to be aligned which is fair enough
Structural changes (parcel tray) - VASS certificate to be supplied
Front End alignment - to be realigned
*plus i have a condition written down than i'm not allowed to drive in the wet until i change my tyres. which is also fair enough.
so its gonna be very pricey :D
some years ago(actually longtime ago) i had my datsun engineered by a workshop in carumm downs...think they were called 'Protek'...
they were the cheapest back then and were a nice bunch of guys, but i am not sure if they are still supplying reports...see if they are on the list.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
