  • Replies 63
you gotta have fully sick spray tags. Nothing says leet than a mad spray tag. Especially the ones which look like ladders or the enemie :P
hehe I reckon the porn ones are more distracting!!
Turn around a corner and some naked chick has her legs spread and looking at you!!! then bang! (that happened to me once....hehe)
ok what time do people play???? maybe we can all get on the same time??
if i get time to it's about 10 to 11 on a week night or 7-8 ish in the morning on a weekend.
i've thought about having a server, but one of my mates had one for a while and it costs a bit to keep runing, plus it's time and energy he wasn't willing to endure for more that 2 months. I don't think i could be arsed either.
I'm definatly up for an SAU showdown however... hehehe
man i miss the CS days
they were da best, junk food and LAN meeting thats da 5hit
Yeah, that brings back good memories....playing late at night till the early hours of the morning, even got the g/f to play CS on occassions against a bunch of other girls on LAN, they get into & are alot more verbally violent :ak47:. My alias' used to be 'ICEMAN' & 'BLADE', might have to try join u guys somethime.
ahhhhh good old CS 1.6
the best cs ever (with fusion pack 10 mod)
i still play everynow and then - but never online
St33_ft owns ever bot on every map (woohoo go me)
just remember to make shopping easy:
b82 b84 b13 b31 (buys kevlar and helmet, then grenade, then desert eagle then mp5 navy)
i always use this combo of weapons when i first start a game until i get more cash - then i usually go the aug or the m4a1 or the scout or cut sick with the machine gun
have fun and p3wn every body and every bot
damn..... got on for about 5 minutes, but had to leave..... couldnt find the particular server you guys were on as not being an optusnet player usually i didn't realise that there are about 10 or so servers.
maybe we should get the numbers up and arrange a specific server and time....
i'm still keen :)
give you some tips.
when using m4 or ak only fire in 3 shot bursts and the realign ur aim. Always aim for the neck or head.
Always keep your guard up. Most people get killed cuz when they are running around their aim height is at an opponents feet/legs.
When you strart a round, get your aim height off of your team mates head/neck. least then you'll know you'll be at the approximate height of your opponents head/neck :P
uhmm stop and listen sometimes. sound is almost the most important thing in CS.
will post some more later but i gotta go.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
