Thats just it GunMetal.
GCG have been around for quite some time and appear to make very reliable turbo's.
Lots of testing and in their earlier fiddlings lots of surge.
They have since pulled the 500hp model as it was possibly over compressored. :rofl:
The GT30 500hp from Horsepowerinabox I doubt with the internally gated .63 will make much more than 250rwkw. As the GCG unit tends to make ~240-250rwkw also.
  • Replies 316
Posted Images
Sorry I think you mis-understood me mate, I am in favour of the GT30 option and was refering to the hi-flow as being a re-engineered stocker. Now that I think about it, putting a .63 nissan style zaust housing on a GT30 is some what re-engineering too :P
I would love to get my hands on the GT3071r below if it was a T3. I agree with you in saying that the horsepowerinabox GT30 with the .63 zaust housing would not make much more than 250rwkw :{
Any idea of the price of the GT3071r???
Sorry for the hijack guys, last off topic post I promise.
Here's a genuine garrett engineered item for us RB30 heads.
550hp
http://www.gcg.com.au/Catalogue_Menus/Garr...tbb_gt3071r.htm
more you want moooore...
http://www.gcg.com.au/Catalogue_Menus/Garr...b_gt3540_iw.htm
That first turbo is NOT a propper Garrett GT3071R . That thing is what ATP Turbo call the GT3071R "wastegated" , HKS call theirs a GT2835 .
The one pictured uses a GT28 turbine housing with a T25/28 mounting flange .
The real GT3071R uses a GT30 turbine and exhaust housing with a T3 flange and non gated .
Hi Ian, what cams did I tell you to buy?  :innocent:
What cams would you recommend for a GCG hiflow with a VG30 ext housing? I am considering Tomei Poncams [ECR33 Series 1 (RB25DET) - Duration: IN,EX 256 Lift: IN,EX 8.5mm] , with Tomei valve springs [To Suit RB25DET Lift ~8.80] and possibly "race porting" the head.
PS: Are the valve springs required? Car is running std bottom end with rev limiter set to 7200rpm.
ive got a hpinabox gt30 with 70comp cover and .63 a/r internally wastegated and it is actually put together by gcg turbos. as for power i got 260rwkws at 20 psi. now my engines is almost fully rebuilt with tomei pon cams i will let you know how it goes. please dont critisize a product that you havent even road tested.
are we talking about the same turbo? no. my turbo is a 500hp gt30. yours is a hks gt30 which although rated at 480ps plus what ever , they can make alot more power than the equivilent garret gt30. im not after stupid comments , im not trying to out do anyone. my gt30 pulls 230 rwkws at 13 psi and 260rwkws at 20psi with internal wastegate and standard cams end of story. im sick to death of people saying thats shit this is better blah blah blah. how about i stick a hks t51r and blow you all away or a t88 which would probably pull 280rwkws at 12 psi , who cares.im not trying to out do anyone i was just making the comment in reply to cubes who said that my type of turbo will have truble pulling 250rwkws . i did not put this combination together to win dyno comps or to try to impress anyone.
Carl,
Loose the attitude. I simply stated it 'may' have trouble pulling more than 250rwkw.
I would prefer the GCG option over the horsepowerinabox option as I don't know the history of development and results the turbo produces.
The point I was making is GCG is reputable, they make reliable turbos and most know it.
I haven't seen results from Horsepowerinabox, I am unsure where they get their turbo's done, when asked if the 500hp internal gate turbo is the same as the gcg item, they stated "its from the same place gcg get their turbo's from"
EDIT: It looks as if GCG does indeed machine up the turbine housings for them.
Well, alot of people are saying a GT30 is a GT30 - that garrett and hks are the same and that gcg or horsepower can make the same turbo as hks
different debate, BUT this was talking about a small turbine AR on a GT30 turbo - and that is why I said what I said. You are splitting hairs about a 20hp difference in rating - and the smaller rated turbo should make less power than the higher rated turbo.
Just pointing out that your turbo's performance is pretty damn ordinary - my comparison was with stock cams too. Dude, if that is the best you can do with that turbo, there are serious issues somewhere else in your setup, cos it just isnt performing well at all. Other guys on here have the same turbine housing and making tons more power than you - even with stock cams - give GTSt-VSPEC a pm and see what he managed.
I am sick to death of people getting defensive on this forum over there average performance. You ask others not to judge without having test driven, well I dont need to test drive to tell you the performance is pretty damn ordinary.
.... im not after stupid comments....
how about i stick a hks t51r and blow you all away or a t88 which would probably pull 280rwkws at 12 psi ,...
anyone notice the contradiction here?
Thats good, because you wont impress anyone. Have a look at the figures you posted, 230rwkw at 13psi, AND ANOTHER 7 PSI TO MAKE 30 KW - what looks wrong here? obviously you have some serious issues - either your setup is very, very ordinary, or as Cubes says, the turbo is really having trouble.
get defensive as you like, your setup is ordinary and needs some serious sorting.
push that turbo out of its efficiency range if you like, I certainly dont care, but to use it as an example of a GT30 with 0.63 housing make over 250rwkw easily - you are dreaming.
But seriously, rather then attacking one another, is it work asking the question, bigcarl are you running a cat, what diam exhaust, what air filter/IC, what boost controller?
You hit the nail on the head, its the setup, not just the turbo. And lets not forget tuners and dynos:( To get some sort of feeling about how it all works you have to look a bit closer, dont you?
But i agree, you are making good power at 13psi, and it seems you having to wind a lot more boost into it for the extra power. Could be worth having a closer look at, you may pick up some free power by having a play:)
Carl,
Horsepowerinabox has yet to prove its self, I am unsure where they get their turbo's done, when asked if the 500hp internal gate turbo is the same as the gcg item they stated "its from the same place gcg get their turbo's from"
When I see quotes on a public forum suggesting my business "may" be supplying turbo's put together by butchers.... I tend to take offense in some form.... Horsepowerinabox is built on customer service, good prices and quality product. I can assure you that they are not put together by butchers!!, and I would consider that we do have been around long enough to have laps on the board in the scene.
The GT30 we offer is not intended to rotate the earth on the dyno, it is intended to provide a bolt on option for the T3 RB guys. It is a genuine Australian sourced Garrett turbo with the RB exhaust housing machined to suit by a Garrett Distruibutor. It has the usual 12 month warranty.
I don't want to get into a tennis match of debate here... but I do want to make the point that forums can be damaging to business reputations so please be a little thoughtful on comments relating to businesses. You have every right to shop where you choose and buy from who you choose and trust, but I think the comments are harsh and unjustified in this case.
Regards
Morrie Huckel
Horsepowerinabox.com
My apologies Morrie,
From my understanding when you machine a housing no matter what to some extent the nozzels are butchered anyway. :)
Offer an option for the VG30DET housing and no doubt it will be a stormer, the turbo will then live up to its 500hp rating, well close to anyway.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
