then its got me mc****d what turbo i actually have then .. if its not a rb20 one ..and it doesnt have the markings of a RB25 and its not VG30 turbo of a 300zx..... what in the hell is it off? ..... if anyone can confirm it for me.. id appreciate it ....greatly
matt
  • Replies 316
Posted Images
Ah shit.
Oh well, I will most likely get them turbo from zoom, as GCG has confirmed it's the right one.
Then it seems that there is NO difference in casting marks or identification between the turbos.
Shite
So reasonably comparable for new, and a bit more than used. Sounds good, comes with warranty so a decent option for those interested.
Ian, I think you are right, but find 220rwkw was too much on stockish suspension so the lod R33 needs plenty to tie the thing down. 280 would be tyre murder :(
Hi Geoff, I've spent more money on suspension than the engine...LOL...Whiteline everything they make for R33 and Bilstein, Strut Braces Front and Rear, Adjustable Caster Rods, Adjustable Upper Rear Camber Rods. And Brakes have been hugely upgraded....Ohh and one of your magnificent Hicas Lock Bars.
Ian
Just to throw another spaniard in the works , there is another exhaust housing by Garrett thats 1.06AAR and twin entry T3 flanged for the TA34 turbos that could work . It has no waste gate so not a straight fit but may work for some .
Cheers A .
So here's what I can figure out.
Stay with me.
RB25DET turbo
OP6 on exh housing
45V3 or 45V1 (series 1 and series 2 or R34 GTT turbos)
RB20DET turbo
OP6 on exh housing
16V on comp cover
VG30DET turbo
OP6 OR V45 on exh housing
16V on com cover.
So, there ya go.
i see what u mean by the exhaust inlet side ..distance.... but can i safely say that its not a RB20 turbo?
Matt
It looks like a rb25 compressor and cover with a VG20 exhaust wheel and exhaust housing.
it is BB. you have an unusual turbo there:)
If its a RB25/VG20 combo it will put out about 215rwkw on an rb20. its exactly what i had on my rb20.
hope that helps.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
