Just wanted to get some advise, I am going to get some alloy cradle bushes, but my question is that looking at the cradle it doesnt really sit up against the frame when the car is sitting there. I have attatched a pic of the car jacked up, but even when the car is lowered off the jacks there is still a gap at the top. This cannot be normal and if I put the alloy cradle bushes in then the top ones will fall out (Will get the easy c shaped ones so I dont have to remove the whole cradle). Anyone got any advise, I will need to tighten them up but need car jacks and hydrolic jack as well.
Cheers for any input.
https://www.sau.com.au/forums/topic/78993-cradle-bushes/
That looks rather odd.
If it only happened when the car was jacked up i'd say it's probably shagged bushes but as it maintains a gap when it's down i think you could have a twisted car/subframe.
Is it only the one corner that has the gap?
https://www.sau.com.au/forums/topic/78993-cradle-bushes/#findComment-1445099
Its actually both sides, having a closer look at it, and even the front ones are a little off the top, but they are not really linked to the rear ones arethey?? (by front I mean the ones just before the rear wheel). What are the possibilities of the bushes just being gone and sagging???
https://www.sau.com.au/forums/topic/78993-cradle-bushes/#findComment-1446003
frame jack = scissor jack?
if so don't do it...too dangerous...
get a good hydraulic jack and jackstands if you want to live..and jack the middle of the diff
like under the drain bolt with wood, not at the fins....
also the bush area...it seems normal, maybe a fraction too much of a space inbetween but
the metal spacers will fill them up...
https://www.sau.com.au/forums/topic/78993-cradle-bushes/#findComment-1452383
I jacked it up off the diff, which iliminated the gap on the rear bushes, but not on the front ones. So I moved the jack and placed it on the subframe on the front (just in front of rear wheel) and removed the gap there again the passenger side seems to be a little sagier. So from that I take it the bushes are just stuffed (not bent subframe), do you think putting the alloy pinapples in will solve it as i just want the C shape ones which means I dont have to drop the whole subframe, but if it doesnt remove the gap then chances are they will fall out from the top???
https://www.sau.com.au/forums/topic/78993-cradle-bushes/#findComment-1452411
ok well I put the alloy cradle bushes in, bought hydro jack and stands, but its making alot of clunking noises, obviously its more solid in the rear, but when I accelerate on and off I get a click/clunk noise, and especially when doing a three point turn, Have a JIC coilovers (Verry stiff) ATS LSD in there which you could feel load up, but now its just way too noisy.
I dont know if something is wrong or normal???
What I was thinking is getting a thiner nolathene pinapples or something to sit between the top of the subframe and the underside of the car to at dampen it. Or possibly remove the top alloy pinapple and replace with whiteline small nolathene bush.
hope someone can offer some help.
https://www.sau.com.au/forums/topic/78993-cradle-bushes/#findComment-1462517
yeah definitley comming from the diff, well first option is to change diff oil to redline, and hopefully that will eliviate some of the noise then depending on how that goes, maybe Bl4cK32 suggestion on fitting the urethane uppers in maybe the next go. The two options of oil and pinapples is prob going to be the best.
Thanks for everyones input, will let you know how i go, hopefuuly the oil will go in tomorrow night, or over the weekend. Some people seem to have mixed results with it removing the clunking.
Cheers
https://www.sau.com.au/forums/topic/78993-cradle-bushes/#findComment-1463994
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
