Does anyone know the backlight colours on these items:
- Nismo's white face 320km speedo cluster
- Trust white face boost gauge
I know Apexi Boost Gauge has blu-ish backlight colour, so if Nismo speedo has the same blu-ish backlight colour, then it will match Apexi perfectly. Not sure about Trust boost gauge.
https://www.sau.com.au/forums/topic/7905-nismo-white-speedo-backlit-colour/
thx nissaner...
so trust boost gauge is definitely DOES NOT have blue backlighting, right?
Cause I wanna match the colour white face when it's off (daylight) and the colour of backlighting when it's on (night time)
they match ok in daytime but not at night Apexi whole face lights up pale blue nismos face is dark at night with only the numbers and logo + pointer and a fuzzy ring around centre lighting up . Nizmo looks good at night and I don't mind the mismatced Boost gauge 'cos it's off side in a pillar mount
http://members.optushome.com.au/jay51/our%...5-32/Instru.JPG
I'm sure you can replace the bulb that illuminates the speedo, etc.
How difficult is it to change actually? I don't mind the standard look dials, but they could do with a more interesting light colour.
I can solder in something else easily enough.
Originally posted by R33-JET
nismo dash is sexy at day and all
but at night it lacks to light up all that good
sometimes u cant even make out the numbers
only my opinion
also have new apexi electrical gauges that light up mad blue
which look crazy at night
First, I won't be doing much night driving, mostly day only.
So white face nismo will look great at daytime when I do my driving most.
Secondly, the nismo speedo lights up in greenish backlit, so I won't buy Apexi boost gauge coz I don't want one thing light up in blue and don't match up with others. So I will go with Trust white face boost gauge, which has the similar colour with Nismo backlit at night. I'm sure someone mentioned this in other thread I can't seem to find which one again.
Anyway, my car's wine red so theme-wise I don't feel it will match well with apexi's glowing blue lights at night... so my choice are fix: Nismo speedo & Trust gauge combination... thx everyone for the input.
Hey Jay...
Does your Nismo speedo cluster comes with all the warning lights like ABS, HICAS,etc? Since it is meant to be for a GT-R, if installed on a GTS-t, will the ATESSA (4 WD system) warning light comes on????
RS73 - I wanted to match my nismo white faced gauges to a boost gauge so I got the Trust one and yes they match.... almost identical. Have a look...
only my opinion
Not to be rude but I think that the nismo dash is crystal clear at night and better than the standard gauges. ALso if you look at the pictures above even in the VERY BLURRED background image of the dash I can make out the numbers. I've had the nismo ones in pretty soon after I got the car and they are clearer than almost any other car. Like RS73 I didn't want green gauges and blue light cos it looks like a circus.
As far as I know all nismo dashes for the R33 GTR are the same except for the white/black combos. And no the warning light does not come on because I believe its for the Active LSD (correct me if I'm wrong) which is only for the Vspec GTR.
thx 400hp, I've been lookin for that pic somewhere.
I can't think where you put your boost gauge....
pillar mount should be on the right, or you mount it somewhere to the left of the steering wheel?
Or your car is left hand drive?
Nah my car is right hand drive... I'm in Sydney dude :P
The boost gauge is mounted on the steering column covering part of the speedo. I don't really care as it only covers 220km/hr - 320 which you won't see often in Australia anyway... I thought about it heaps where i was gona mount it. I didn't wanna get defected for the A-pillar and didn't want to drill. Anyway I'm happy with it.,
u have to pull out the whole dash console to get to the bulbs!
rs73
if u want the apexi boost gauge to match your dash get the EL dash kit like mine.
INASNT,
I'm after the 320km/h speedo from Nismo, which has greenish colour backlight (the numbers only). So Apexi EL gauge is out of the question, and I am going with Trust gauge as the backlight colours match the Nismo speedo nicely as shown by 400HP's picture above....
Originally posted by rs73
INASNT,
and where exactly are you planning on doin 320km/h?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
