Track Day cancelled, now a cruise and BBQ SUNDAY 16th Feb 2003
  • Replies 160
:lol:
You just have to look at the kit, wing and chromies!
He convinced another mate of mine to get a wing like his. Probably cause aerodynamics comes into play at 40km/h....
does anyone know number casue the catering team
eg .................. me
has to organise banggers ect
(i got a new set of tongs for christmas)
dan give us a bell so we can divi out who is bringging what
and also anyone out there have a set of 255/40/17 casue i seem to go thorugh them like they r going out of fassion
and finally whoever borrowed my lock nut key last track day
give the ***n thing back or i will kill you (try changing a tyre without it)
pete
Fatz... you are a dick head... and bonkers said to tell ya his car got a polish the other day!!!
Carlo,
Sounds good, ya gonna get one of those switch clutch things like I have? (Either engaged or not)
All,
Confirmed and payed parties are as followes:
Roy
Majanal
Duncan
Kel
JR33
Brendanf
Silver + 1
TEX + 1
Carlo
Brett
Dino
Nissaner
Bonkers
drifto
Fatz + 1
Julian GTS-t
Zane + 1.
This is 21 people and I booked for this number today.
the following is a list of interested people that would like to come but have not offered a deposit. Spots might be able to be arranged for you on the day and if any one does not show then a first in first served basis will apply.
Grim
Oz_GTR97V
NOF41R
fatz and Silver, would you be happy for the Club to re-imburse you for LPG, snags and rolls with the proceeds of the BBQ to go to the Club?
The Club bought an Esky today so we'll be selling cans there.
Originally posted by Duncan
Hahaha, watch out Dan, I heard in another thread that Bonker's likes the look of your mum......
Yeah but he offered for me to sleep at his sisters as a trade off... sounded fair to me!
Fatz,
Do you think about 3 KG's of snags and some onions should be ok? and do you want those rolls again... or just grap some bread in the morning?
All,
Booking has been confirmed.
Need to be at the track no later than 8am... I'll be there at 7:30am so we can start filling out forms etc, they have to be to Tracey with the balance of payment by 8:15am. Make sure you come and see me before seeing moto staff, otherwise you will pay extra.
My mobile number: 0414 940 938
Dan.
Originally posted by nissaner
whos going there from northside area? i don't want to drive there all by myself... brendanf, u live around north right? wanna cruise down together??
Yep, sounds good ! Let's see what Dan has to say soon !.... The last two posts by Dino and Duncan area a bit of a worry.......
***EVENT CANCELLED***
Motoconcepts informed Majanal earlier this evening that this day has been cancelled. Apparently Oran Park have decided they needed the track. Seems like a VERY strange way to do business, but we'll know more when Dan logs on...:starwars:
So I guess a cruise is in order...any suggestions????
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
